Question about Hotpoint Refrigerators
The freezer is not freezing and refrigerator is not staying cold.
    President:
  • 2,187 Answers
You may want to check first the coils found behind the freezer if there us ice build up. Have it melted and cleaned. Have the thermistor checked if it is working. It may not be sending the correct temperature to the control board.
Posted on Sep 27, 2009
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Jun 21, 2008 | Refrigerators
Refrigerators Logo
96 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
