Question about Jandy AquaLink RS2/6 All Button Dual Equipment -
Just replaced the heat exchanger, when I tried to fire the heater my jandy control panel shows a "water sencer open" message. Instructions say heater will not fire when the message is showing, whats the fix?
    Champion:
  • 246 Answers
Sensor? when they work at the heater they pulled and disconec wires inside the control
Posted on Oct 15, 2009
Why won't my heater heat past 100degF?
Probably a bad thermostat. We have replacement thermostats at poolsupply1.com
Nov 03, 2014 | Pool & Spa
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
My jandy xl 250 pool heater runs great for 5-6 minutes with a blue flame then it turns orange and runs hot ive replaced all 5 burners wire brushed and power-washed the heat exchanger. I tore it all apart...
bad mixture is correct. heater is under firing, lack of oxygen, hence the immense amount of soot or carbon build up underneath heat exchanger. Is heater inside a shed? if so u need 2 vent openings to provide combustion and ventilation air. vent blockage can also cause sooting and over heat conditions. your repair guy lacks alot of knowledge. burners and heat exchangers can be cleaned. i can give you a list of reasons of possible problems that im sure were never mentioned or checked
Aug 11, 2013 | Pool & Spa
I have a Jandy XL 250 natural gas heater the exchanger was sooted up the burners were disfigured from overheating so ive cleaned the heat exchanger replaced the burners and the front panel still gets very...
Simply put, your heater is not (and hasn't been) getting enough gas. You should check to see if your gas line is properly sized for its distance to the meter, and if the meter is big enough to properly supply the heater. Water in the gas line will also starve the heater for gas. Good luck with it.
Aug 10, 2013 | Pool & Spa
I have a leaking Heat Exchanger in my Jandy Hi-E2 Pool Heater. Do you have instructions for replacing it?
major overhaul call a professional if not correctly done waste of money or buy a new heater
Jun 27, 2011 | Jandy Laars Hi - E2 350,000 Btu Heater
Jandy Lite 2 LJ Water Leaking
I have the same problem, removed the heat exchanger and found a small rubber gastket that was ripped. The gaskets can be found at parts store. Set of 18 about $20.00.can.
May 27, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
Heater leaks water on lower left side (side where gas attaches) towards rear. Do not want to take totally apart to get to leak. Side does not appear to come off.
The heater sides do come off. Your heat exchanger will be what is leaking. Some people (I have never tried) have had them welded at a local radiator shops with some sucess though it is likely the heat exchanger will have several thin areas likely to fail in the near future if you have a leak now.
New heat exchangers are expensive. If you would like a quote, contact us with your heater model and serial number at www.arrowpools.net.
The longer you leave it leaking, the more likely you are to damage other parts down in the bottom of the heater so it is not something you should let sit. If you are going to go without it for a while, close the water off if you have a bypass. Otherwise, consider having the plumbing re-arranged to bypass the heater.
Oct 08, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
71 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
