Question about Orion1934 19" TV
I HAVE AN ORION MODEL 1934A TV. CANNOT ADJUST VOLUME ON SET. LOST MY REMOVE. EVERYTIME I TRY TO LOWER VOLUMBE, THE TV TURNS OFF.
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: TV PROBLEM
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Posted on Apr 13, 2008
rockitman187
  • 2559 Answers
SOURCE: How to turn off close caption on Orion TV 1934A
Just press the cc buton on the remote or go into the menu using the remote and turn it off
Posted on Jul 22, 2009
DerStrom
  • 103 Answers
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Posted on Apr 06, 2010
I have a orion tv/dvd/vcr, model ftdv2004 i need
Hello
Three digit universal remote codes for Orion are:
035/ 121/ 135
Four digit codes are:
0121 0135 0035
Aug 26, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Apr 06, 2010 | Orion STV2763 27" TV
Try unplugging your TV while it is on. This will cause the Factory Defaults to restore. When you turn it back on every thing should work normally again
Jul 22, 2009 | Televison & Video
I have an Orion TVD 2710. Need to adjust resolution.
if you have a menu button on tv shoul be able to do it there after you push the menu button then use the up or down button for selection then the volume up or down to ajust then menu to exit. Now if no menu button sometimes you can push the up down chanel button at the same time and get into the menu. Hope one of these works.
Feb 20, 2009 | Orion STV2763 27" TV
Lost password
Turn the volume down to 0 then change to a blocked channel. (where it asks for v-chip password) Next, on the TV, not from the remote, hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions.
Jan 25, 2009 | Orion1934 19" TV
Orion tv
Hi Gerald P, just posted we experienced same problem. Few minutes later my husband has finally solved our problem. Don't know whether you can try the same. We had an old FOXTEL remote, got onto FOXTEL site and instructions how to program remote to control TV.
Dowloaded instructions with code for TV (after trying a few tries, the fifth code solved it). FOXTEL control needs to be programmed with the code suitable to TV. By pressing "ON", "AV", Red button and Select (at same time) then put code in. Turn "OFF" then "ON" see if code complies. If not try another one until you get it.
By using the FOXTEL remote on the "AV" you can change the channels on the TV and adjust volume up or down as well.
Hope this can help you in your situation. Glad we are up and running again. Bye
Jan 23, 2008 | Televison & Video
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    TV PROBLEM
    Jerry G.
    Nov 21, 2007 | Philips 28PW6506 28" TV
    Orion 1934A
    You can check for fuse and fusible resistor, also horizontal output maybe shorted
    Aug 30, 2007 | Orion1934 19" TV
    Orion1934 19" TV Logo
    70 people viewed this question
    Top Orion Televison & Video Experts
    wayne chamberlain
    Jerry Greenberg
    Jerry Greenberg
    Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
