Question about Garmin Edge 305 GPS Receiver
The unit shows no signs of life, when i plug it in, i have the same problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Try soft reset :
hold lap/reset and mode buttons for ten seconds, then release and wait 10sec, then hold start button for 10 seconds, device should start
Posted on Sep 10, 2010
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Presario 2200 laptop not working
Take the power plug out, remove the battery. Press and hold the on switch for 30 seconds to discharge any voltage inside. Plug in the power unit and try to boot.
Nov 13, 2013 | Computers & Internet
No power
Look if you can safely get it apart for the fuse inside the unit and if possible test the power cord and where it connects, this is the place to begin---total dead units are usually easy to fix, follow the AC voltage from the wall or voltage source inside to the fuse etc.
Dec 20, 2012 | Acer S242HL bid LCD Monitor
Engine cranks but will not start. Spark plugs changed, HEI distributorless ignition unit tested good.where do I go from here?
Spray some starting fluid into the intake, and see if it shows signs of life. If it does, then you have a fuel delivery problem.
Now, a 1991... That's fuel injected, yes? Throttle body injection or port injection?
Jul 07, 2010 | 1991 Plymouth Grand Voyager
The unit shows no signs of life, when i plug it in to charge it does not indicate that it is charging, it will not turn on
Try soft reset :
Sep 26, 2009 | Garmin Edge 305 GPS Receiver
My washer shows Lr sign on the pad.what does that
that is a locked roter sometimes caused by sudsin unit
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unit not running, not cooling electronic
To operate, a refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run:
1) Check the power. Make sure the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn't work, check for a tripped circuit breaker or blown fuse.
2) Be sure the cold control is turned on.
3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson
Jul 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Polycom Fx doesn't power on or show any signs of life
Try disconnecting the ISDN module and then cycling the power. If that doesn't work speak to your support provider about repair costs. Ultimately you may need to replace it because of its age (it might be End of Life and not available for repair)
Sep 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Garmin Edge 305 GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
