Question about Westinghouse SK-19H210S Television
I have taken my Westinghouse LCD TV, model # SK19H210S,. apart now I need a book for dummies! I am attempting to replace the capacitor.Went to Digikey to try to figure out what part I needed and it gives me sooo many choices that I don't know which one to order. could you please tell me what to order?
Check the 2200 MFD capacitor on the power supply board. If the top of it is slightly domed up, it is bad. Check the top against the other capacitors on the board to see how the tops look. I got a 16 volt 2200 MFD capacitor at my local Radio Shack. It was in the assorted pack of capacitors 272-802 for $4.95. The package had 3 capacitors this size.
Posted on Dec 24, 2009
I just did the swap and made up some instructions if it helps. Shoot me an e-mail and i'll send them to you in PDF format.
Digi-Key part number P10230-ND, $0.90 each
Panasonic part number - EEU-FC1A222
Posted on Dec 04, 2009
This might help.. posted on this forum.
"terryt512
Rank: Apprentice
Rating: 0%, 0 votes
Check the postings on replacing the 2200MFD capacitor (CE105) on the power supply board with one rated at 16V. Make sure to get the polarity correct when you replace the capacitor. Worked on the one I fixed for a neighbor."
Posted on Sep 30, 2009
The back lighting on this TV is too bright and this is not due to the settings. What may be causing this problem and how can I fix it?
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 17, 2016 | Westinghouse Televison & Video
Westinghouse TV picture started flickering, the next day screen went black.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 02, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
No power Westinghouse LD4655BX
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 04, 2014 | Westinghouse Televison & Video
I have a Westinghouse LCD screen model LCM19v5. The other day it stopped working. It will turn on for less than a second and then shut off. I changed all the wires and even hooked up a new LCD screen to...
Thanks for the pictures, it makes it easy to determine that these two capacitors need to be replaced. Whenever the tops of the capacitors start to bulge or the the vents actually rip open, the capacitor is bad. A normal capacitor should have a flat top.
You need to replace the capacitor with the same capacitance and at least the same if not greater voltage. These capacitors have a polarity, so when you replace them, be sure that the lead white strip with the minus sign is inserted to the negative hole on the board.
Hope this helps!
Jul 19, 2010 | Westinghouse LCM-19v5 Monitor
Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television I have a 32" tv Westinghouse, it was on went I hear a sharp pop like glass breaking, I unplug it for a willy plug it back in and nothing happen what...
Ur power supply board is dead.Take ur tv aparts,replaced the power supply board.Ur tv will get ur power back an the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a westinghouse sk19h210s will not turn on. replaced 2200uf 10v capacitor with a 2200uf 50v was told the volts wouldnt matter but it still does not work.any input would b helpfull
their right volt rate will not matter as long as it is higher do you have any other indecation of the unit getting power? if not check you fuses if so you mainboard could be your problem check carfully for more bad caps
Nov 19, 2009 | Televison & Video
I have sound but no picture a all on a Westinghouse LTV20v4. The menu does not come up.
Check for bad capacitors in the inverter board, it may have taken out the 8 transistors when the caps went open.
See the picture here: http://s807.photobucket.com/albums/yy352/budm/WestingHouse_LTV-20V4/
Nov 07, 2009 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
Westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Mar 05, 2009 | Westinghouse SK-19H210S Television
Westinghouse HDTV
I bought a 32 LCD Westinghouse TV 12 months ago. It stopped working so I brought it to a TV repair shop. They determined that the main board went out. The TV's power supply is working but there is no screen or sound, nothing. The TV repair shop had to call Westinghouse to inquire about a replacement part. Funny, Westinghouse doesn’t make replacement parts for this TV. Westinghouse said we need to ship it back to them and they will send us a new TV. Okay that sounds good but they wont pay the $100 plus shipping costs for us to ship the broken TV back to them. Also, they make you send them the TV before they send you the replacement TV. That can take days. If the customer's TV went out because of the company’s faulty product, the customer shouldn't have to dic around with this shipping issue – Waa, Waa! The TV was nice but for it to conk out in one-year shows what shi++y merchandise Westinghouse is selling their consumers. “Buyer Beware”
Feb 28, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
991 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
