Question about Motorola Mobility Rival A455 Cell Phone
Goes right to a white screen and stays like that
.even when i charge it,or take the battery out .itgoes right to a white screen and stays like that.the two bright whit buttons still light up and vibrate if you touch them but the screen stays white.what do i do?
    Problem Solver:
  • 5 Answers
Transfer all your contacts and pics to ur computer and go to phone , then security , then press reset , enter your code which is the last for digits of ur number unless u changed it and it should work , when you unplug battery for about 2 days , to be safe
Posted on Oct 04, 2009
Hp probook 4520s charging time more brightly .battary off time darknessly
Laptop screen is normally brighter when it is connected to the charge adapter. When the laptop is running on the battery it is usually a little dimmer to save battery power, you can adjust the screen brightness even on battery power. To adjust the brightness hold down the Fn key and press one of the function button keys it maybe the F7 or F8 key it will have a symbol on the key to indicate the screen brightness.
Dec 18, 2012 | HEWLETT-PACKARD ProBook 4520s
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
Dec 01, 2012 | Computers & Internet
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
The sansa screen stay always white can't do
try resetting it
Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 07, 2010 | SanDisk Sansa Fuze MP3 Player
Screen will not stay bright
That's the battery saver feature of that Philips portable. If you use an A/C power adapter, the light will stay bright.
Hope this helps!
Sep 10, 2009 | Televison & Video
Samsung NC10 Screen goes white when plugged into Charge
I too had this problem with my NC10, and i found that on the back, the little slider holding on the battery casing was not in the locked position. As soon as I locked the slider, the problem was solved and has not occurred again.Might not be the case for all these posts above, but worth checking your before having to get involved with customer services etc.
Aug 24, 2009 | Samsung NC10-14GW Notebook
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Sep 17, 2008 | Fuji FinePix J10 Digital Camera
Samsung S73 batteries
i am having the exact problem as you are having have you figured anything out? Thanks!
Dec 27, 2007 | Samsung Digimax S730 Digital Camera
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Rival A455  Cell Phone Logo
288 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
