Question about Kenmore 46462 Front Load Washer
My front load Kenmore washer has a f03 code on the screen. It is not draining the water and it is not doing a max spin. What do you think I need to do?
  • Kenmore Master
  • 19,396 Answers
F03 error code means that there is either fill problem, a drain problem or a water level pressure switch failure .
First ensure the machine is filling.
When the drain system is causing the F03 error do the following.
Ensure that the drain hose is not kinked or clogged.
If the drain hose is OK check the drain pump.
Start unplugging washer from main and remove the service panel at the bottom.
Follow the instructions on manual to remove panel.
Access the water pump and remove the hoses, clear any blockage in there.
Use a container to collect the water, be prepared. If machine has lot of water inside, remove some water with a sponge before undoing the pump.
Posted on Sep 27, 2009
There is not really a solution, i have also received codes on my washer F3 and E01, there is no water that is coming out when it starts and I already changed the pressure function that it requested to change and still no responce.
Posted on Jan 15, 2014
What does code f03 mean
An F03 error code on many front load washers indicates a failure to drain properly. You can usually clear this fault code by pressing the pause/cancel button. Next, check the drum for water. If the drum still has water in it, restart a drain and spin cycle. This should drain the water from the tub.
If your washer will not drain, check the drain hose for kinks or clogs. Make sure that the drain hose is not stuck more than 8 inches down the stand pipe.
If you do not hear your drain pump running, you may have a problem with your control or your drain pump. Also, if your pump is making a loud noise, it may be clogged. These problems would require service by a technician.
May 19, 2015 | Washing Machines
Problem with spinning clothes
Hi
Error code F03 on Kenmore means that there is draining problem or a filling issue with the washer. Check if the washer is draining; also make sure that it is not kinked or clogged. If the drain hose is not kinked then next thing to check is Drain Pump. Check out this link to disassemble your washer---
Kenmore Washer disassembly
Now, check the drain pump for any blockages. Make sure that you have a container to collect water when you open drain hoses from the pump as it has a lot of water inside.
If the drain pump is fine then it is an issue with filling of washer. Check whether washer is filling and the pressure is fine. Also, make sure you check the softener dispenser. Pull the dispenser drawer out and clean it thoroughly. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. Please post back for any further assistance.
Daniel
Aug 02, 2010 | Kenmore 43142 Front Load Washer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine wont drain F03 message is
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Jan 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Code F03
Typically a low water or no water coming in problem. Sometimes a drain problem.
Feb 25, 2009 | Frigidaire FWTBB30DS Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Kenmore 46462 Front Load Washer Logo
948 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
