Question about Frigidaire GLTF2940ES Front Load Washer
Washer Stopped Spinning
My Frigidaire front loader (LTF2940E) made a very loud BANG during what I think was the drain/spin cycle and now won't spin. Does this washer have a belt and if so, how difficult is it to replace?
thx,
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
Posted on Dec 25, 2007
My frigidaire affinity pauses during the cycle and won't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
The machine is not draining and it is not spinning
Your machine will never spin if there is water in the tub. Remove the pump and clear the obstruction.
Jul 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Aug 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
433 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
