Question about Nikon CoolPix S2 Digital Camera
No display on monitor
No picture on the monitor
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
My monitor will not display a picture, every now and then my screen saver is on displaying the picture as if there is nothing wrong. Help
I just hooked up the Soyo moniter to my Dell XPS M1210 laptop and it won't display. I went to the Dell manual and it said to go to Start, click Control, Panel, click Display, Click Settings but when I go to the Display part the option is not available. Help please.
Jun 17, 2011 | Soyo DYLM24D6 LCD Monitor
My samsung LCD monitor display blank but blue light is blink.
Check to ensure all connections are in good place and are properly connected, if they are and yet no display, the picture board on your monitor is faulty, since the power light is on, it means the picture board of your monitor has developed fault.
take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Dec 10, 2010 | Samsung SyncMaster 740N (Silver) 17 inch...
Monitor slow to display picture
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
Feb 10, 2018 | LG Flatron Computers & Internet
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I...
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Mag Innovision InnoVision LT865s 18" Flat...
My monitor got bumped in a move and all of the text on the display is now fuzzy....any suggestions?
The picture board on your monitor is malfunctioning that is why the display is now fuzzy, This is a sign that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
Will not show picture and camera is working. Is
Not too much info here. Based on your statement, I'm guessing you are trying to connect a digital camera to your monitor to display pictures on it.
1) Does the monitor work fine as a monitor on its own?
2) Make sure you're on the right display/input setting on your monitor.
3) How do you know the camera's TV-out function is working? Have you tried it on other TVs?
Its possible that the camera is not in display mode. Its also possible that the camera's TV-out is not working. Its also possible that something about the output from the camera is not compatible with your monitor. I would try the following:
1) Test the camera on another TV to make sure the TV-out is working.
2) If its working, go to the appropriate input/source setting on your monitor, before connecting the camera. Then connect the camera, when the camera is off. If nothing displays then turn the camera on, and see what happens.
If that doesn't work, it may be possible that your camera displays in a different set of settings (resolution, etc) than your monitor is able to display. Also I would check the manual for your camera to make sure there isn't some way to adjust the settings.
Feb 16, 2010 | ViewSonic NX1932W LCD Monitor
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Dual monitors in XP Pro - HP Pavilion zd7000 laptop & I-Inc CY199 monitor
in that case u need a video hub, like : display booster. we call it a vga display booster. this may increase the quality of a picture. because when we attach any display unit, the image appears in two portion. it's gain is to low. to make it more sharp, monitor itself add some colour to that picture. the vga signal is fixed from inside of the monitor with resistance, so u can't make any variations in picture. that's why u guys need that VGA booster.
Jan 14, 2008 | Computers & Internet
Nikon CoolPix S2 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
