I just loe the connection of the person trying to elp me. we are tryingto correct a roller on the cartidge of the HP psc 1210 all in one printer
    President:
  • 1,462 Answers
Hi, Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent. NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause Any of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
please leave me comment, if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 27, 2009
Paper wont feed on my hp psc 1210 all in one printer
open the door at the back of the printer and clean the rollers.
Unplug the power cord at the back of the printer while it is still on and then after 30 seconds plug it back in.
If it will still have the same problem then there is a problem with its sensor.
Good Luck!
Jul 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
I dont have a cd to install hp psc 1210 all in one
do not worry sir here is the link where you can download the program and install if for your psc 1210 printer. Once you open the link select the correct model from the list and then select the operating system and start the download once completed start installting and do make sure the printer is connected to the computer and it shoudl be turned on.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=+PSC+1210
Feb 25, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have HP PSc 1210 all in one printer. It does not load the paper. It makes grinding noise as it is trying to load it. But does not work. Any help will be appreciated.
the noise is coming at the time of cleaning the cartridge.you can remve the printer top cover and right side of the printer you can see the waste ink pad .clean the pad and cartidge cleaning pad. put some grease in the cartrige cleaning pad moving unit area.
Sep 25, 2009 | HP PSC 1210 All-In-One InkJet Printer
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90764
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3635378&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&lang=en&cc=us
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
NEED DRIVERS INSTALATION HP PSC 1210 ALL-IN-ONE
my printer hp psc 1210 lost instalation cd . where did it download?
Jan 10, 2009 | HP PSC 1210 All-In-One InkJet Printer
Driver for hp psc 1210
hello!!!
the printer driver of your
click here
Sep 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
Unresponsive printer
First off, I will try an uninstallation of the printer
Then reinstall all the drivers and software for the printer.
Jan 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
i need hp psc 1210 driver for windows vista (64 bits)
Oct 01, 2007 | HP PSC 1210 All-In-One InkJet Printer
Problem with HP PSC 1210 All-In-One InkJet Printer
maybe there are some conflict with your hardware, a webcam connected to your computer when you install HP driver will cause problem. u may not solve it anymore than reformat. do not connect all components readily. connect and install HP first, then connect and install tv card maybe, last connect and install webcam.
May 14, 2007 | HP PSC 1210 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
