Question about Dishwashers
Drain solenoid burned up. Could it be the timer motor?
  • Dishwashers Master
  • 2,605 Answers
If the drain solenoid is burnt, it is most definitely the timer,(which is what I assume you meant anyway) not just the "timer motor". those solenoids are only meant to be energized momentarily, once the "gate" is open for the drain, the flow of water keeps the drain "gate" open. the timers have been known to energize the solenoid too long, hence causing them to burn out. replace both the timer and the solenoid and you'll be fine.
good luck
Posted on Sep 27, 2009
Ge americana dishwasher m#adw1100n10bb is not pumping out water and burning up silenoid to pump can smell silenoid burning
Sometimes the timer on this model will stall out and cause the solenoid to burn up, this unit doesn't have a separate drain pump so the solenoid would be why it isn't draining. It's possible that the new solenoid will take care of it with no other problems but if it burns up again then you may have a bad timer
Jan 28, 2014 | Dishwashers
Dishwasher will not drain. power is ok drain hose is not plugged disconnected hose from drain plug was able to siphon smome water through Start washer, then press cancel, get a noise, probablely...
Hello. There are several possible causes for your problem. Let me briefly go through each one and then you may be able to zero in on your specific issue. I will try to include the fix for each.
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Pump The pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. Motor If the motor isn't turning or working, the unit won't drain. If the motor hums but doesn't turn, it may need to be replaced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Dec 07, 2009 | Maytag Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Ge gsd5620 dishwasher
Hi. There are several possible causes, let me explain:
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Jul 28, 2009 | GE GSD5620DBB Dishwasher
Water will not drain out
Drain line/air gap
Pump
Belt
Motor
Timer
Jul 14, 2009 | Dishwashers
Dishwasher won't drain completely . It is 2 years old with very moderate use. Drain mechanisms have been checked and seem to have to clogs.
Hi..
If the water doesn't drain from your dishwasher completely, check these:
Drain line/air gap
Pump
Drain valve and/ or solenoid
Belt
Motor
Timer
Drain line/air gap
Pump
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Dishwashers
Dishwasher runs for very long time, doesn't clean well and won't drain completely
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap
Pump
Belt
Motor
Timer
Good Luck!!!
May 06, 2009 | Dishwashers
Maytag - MDB4800AWB - water will not drain
If water is not draining, check first that the drain hose is not obstructed. Try also advancing manually the timer/[programmer.
If water is still not draining, it may be a faulty drain pump, aproblem with belt/motor , or a defective timer/control panel.
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Belt
Motor
Timer
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon."
from The water doesn't drain from the machine
Sep 27, 2008 | Maytag 24 in. MDB4000 Built-in Dishwasher
Water will not dain after washing
Drain line/air gap
Pump
Belt
Motor
Timer
Aug 05, 2008 | Whirlpool Dishwashers
Water in bottom of washer after fast cycle complete
Drain line/air gap
Pump
Belt
Motor
Timer
May 04, 2008 | Dishwashers
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
