Question about OKI C5100n Laser Printer
OKI C5100 M toner senor error
I have a "M toner sensor error" on my C5100 OKI printer. I swapped the M and K toner catridge (The complete unit) and the error goes away - naturally the print colors are not correct but the printer works. When I swap them back the error comes back.
When printing on my oki c5100 text or image - it prints fine but with a smudge/ghost of the image or text also on the paper. I know I need to order new toner - could this be why?
Open you printer and pull out the fuser assembly and look if the upper roller is fine because if it`s damaged it could lead to the double image.
Oct 20, 2010 | OKI C5100 Laser Printer
Message on window: check toner cartridge 542: C toner sensor error
try a different toner first .... doesn't have to be a full one ... just a different toner box. had the same on a machine and it was only a bad toner cartridge. so the easiest thing to do is swap drum units with toner installed ...
if it turns out to be the cartridge you can have a look at the right side ... there is a hole in it and a white plunger moving there and gives the machine the current toner amount in the cart.
Oct 24, 2009 | OKI C5500n Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
Okidada C5100 `
An error has been detected in your printer's Control Panel. You should restart the printer, and if the same problem reoccurs, you will need to have the printer serviced. Problem seems to be pointing to the cyan toner sensor
Dec 16, 2008 | OKI C5100n Laser Printer
I think I need to replace the fuse in my Oki c5100 printer.
I bet you don't need to replace the fuse, these machine have a FUSER that needs to be changed, it is the hot bit at rear, after the four toner and drums, two locks right and left, lift black unit at rear out, replace unit called a FUSER (melts powder to paper ie fuses it)
Nov 20, 2008 | OKI C5100n Laser Printer
OKI C5100 Making grinding noises
Click the following link, it should solve your problem
http://www.fixya.com/support/t238726-sensor_error
Regards Wayne
Aug 05, 2008 | OKI C5100n Laser Printer
OKI Printer C5100 problems
probabily u have some message on the printer display, and your problem must be Toner low, u will ned to replace toner.
Jun 26, 2008 | OKI C5100n Laser Printer
OKI C5100 only printing cyan
I need to know if the test page that the unit prints as "Demo Page" comes out fine. If this is the case, your problem is within your application (software) or computer connection (check all cables). If this is NOT the case, I'll need to know more about your scenario. Operating system, type of connection (USB, parallel) and what are you trying to print. I'll be waiting.
Sep 27, 2007 | OKI C5100n Laser Printer
OKI C5100n Laser Printer Logo
554 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
