Question about Dryers
Cord got real hot and smoked at wall plug!? - Dryers
  • 1,531 Answers
The you have some kind of direct short check the wiring on the back of the unit and make sure that the terminal block is in good shape.also need to check the main plug
Posted on Sep 27, 2009
Cord gets very hot
That is a fire hazard, do not use it, it will start a fire and possibly kill you.
Jan 21, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
The power cord of my TV is getting hot
Major, major problem.
Does the outlet hold onto the plug securely? If not, then replace the outlet.
Try another outlet, does it get hot there as well? If not, then replace the outlet.
If the plug gets hot while the cord remains decently cool and the wall outlet is good, then replace the plug on the cord.
:o)
Jun 03, 2011 | Kitchen Ranges
Mitsubishi tv vs 60707 fuse keeps blowing everytime i plug it it
1. unplug from the wall
2. cut off the end of the power cord
3. splice the plug from an extension cord
4. tape it up real good
5. try again
Feb 04, 2010 | Mitsubishi VS-60707 60" Rear Projection...
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Grill problems
I would advise not to use the grill or the plug it plugs into before determining what the problem is. It could be the grill cord, or the wall plug.
If you have been in the habit of pulling the cord plug out of the wall by tugging on the cord, then chances are the problem is broken conductors inside of the wire insulation. One way to test this is to attempt plugging the unit into a totally different wall outlet. If the cord and outlet heat up again, chances are the cord needs to be replaced (if possible). If the both do not heat up, then the outlet wiring connections inside of the wall need to be checked.
Bad wiring connections either in the wall, or in the cord, will generate heat, when will then conduct to the other connector. So it is difficult to use heat as the indicator of which connector is bad.
Dec 10, 2009 | George Foreman GR36P
Black and decker blower cord smokes when pluged in and trigger is pulled
Suggest you not use this equipment. Either you or someone else could be shocked. If the blower cord is getting hot, so is the drop cord. Something may melt and cause a fire. My guess is a short in the blower unit itself, which should only be addressed by a professional or replaced if too old to fix.
Oct 24, 2009 | Garden
Power cords
Yes,
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
Apr 17, 2008 | Televison & Video
Patton PQH307
Wires are rated to handle a certain amount of amps. Your dryer cord is bigger than your coffee maker cord because your dryer pulls more amps. What is going on with your heater is your heater is drawing more amps than the wire can handle. Therefore the wire is getting hot, melting the insulation. Hopefully it shorts out before it catches on fire!!! BOTH BAD SCENERIOS!!! It is possible your machine is just excessively dirty, therefore working extremely hard, drawing high amps. If you are able to give a good cleaning, do so. Let dry and turn heater on DURING A TIME WHEN YOU CAN MONITOR IT, NOT OVERNIGHT. See if it has made a significant improvement. If not, it's time for a new heater!! Best Wishes!!
Nov 28, 2017 | Patton Heating & Cooling
Defective plug Honeywell HZ 680C
just change the plug - get it at a hardware store. if your cord is flat, the center conductor is earth ground, green screw. the ribbed conductor is the neutral (white) and the ribbed conductor is the hot (black)
Dec 06, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Dryers Logo
Top Dryers Experts
