Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I can not find the model number. I need the small pulley that changes direction from the front to one of the blades.
  • 389 Answers
Look underneath the seat for the model number sticker. It will be a number that starts wit 917. and then 6 numbers after that.
Posted on Sep 27, 2009
  • Chuck
    Chuck Sep 27, 2009
    BTW if your model number sticker is totally missing, you can remove the pulley you need, get me some measurements and information and I might be able to locate it in my cross-reference guide. I will need: Outside diameter - center hole diameter - width of the pulley at the outside edges - whether is is a v - idler or a flat idler - whether or not it has a spacer bushing on one side
I have a vintage Murray Riding Mower, model number is missing has three blades each blade is 15.5 inches Need belt diagram to install both belts to deck
If you have info numbers off the engine, usually found stamped on the top front area, it should at least give you an approx. year.
Sometimes there is a belt diagram under the foot rest area.
Worst case : The belts always fit/sit with the flat part to the flat pulleys and the v part of the belt to the v pulleys.
Oct 24, 2015 | Murray Garden
Poulan 271491
Trina:
Your belt may be the wrong size (diameter too small)... turn the tractor off, and release the cutting lever (as if you wanted to make the blades stop). pull in the belt to see if there is any slack in the belt. If there is no slack, your belt is too small and you will need to buy a larger one. Another thing to check...one of the pulleys may need attention. check to see if the pulleys are clean (no rust or dirt where the belt contacts the pulley). turn the tractor off and see if any of the pulleys wobble when you try to wiggle them with your hand. If one of the spindle pulleys wobbles, (The spindle pulleys are the ones directly above the center of the blades), you will need to replace the wobbly spindle(s). The drive pulley is on the motor driveshaft. check to see that it is clean where the belt contacts it, and the pulley is not warped or damaged. The other pulley is an idler pulley. check to see if it is damaged, warped or dirty.
Aug 31, 2013 | Garden
Changing Blades
With most small lawn tractors I've dealt with, you want to unhook the deck-blade drive belt, some have one large belt that turns the blades as well as the rear wheels, others have more than one belt.. usually you will find four brackets that suspend the entire mower deck below the lawn tractor. To locate these brackets raise the mower deck so that its not resting on the ground, then push the mower deck side to side and notice where the attaching arms are moving under mower but above the deck, once you find the four brackets, lower the deck 2 its lowest point. remove the connecting pins noting the exact hole each pin came out of, if you have not removed the belt bye now do so at this time. you may find a stubborn piece of metal preventing the belt from coming off near the larger pulley Don't bend it out of the way just remove or loosen its nut,its there 4 a reason. so now, 1 the belts off the pulley. 2. the pins or bolts have been removed from the suspending arms and the hole positions have been noted. remove any other actuating rods or levers remaining so that the mower deck can slide out from under the mower. you may have to put the front wheels on a 4x4 blocks or similar to accomplish this. once you've got the deck out carefully turn it upside down, use blocks to keep from mashing pulleys, etc. you will probably see two or three blades, remove hex head bolt w/ washer holding blade to spindle, be sure to note cutting side of blade and direction of travel. If you don't see bolts in the center of blade look for my other solution for changing blades and blade bearings.
Jul 16, 2013 | Garden
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
My belt came off and I need to know how to put it back on?
There should be 4 pulleys.2on the deck that are above the blades,put the belt on those first.
There should be a tension pulley,with the engine OFF,look on top of the deck and engage the blades.Note the direction the tension pulley moves,the belt must pass inside that pulley.Now disengage the blades and put the belt on the engine pulley.
May 11, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
The belt is skipping. We lubed it but the problem continues as if it may be a gear slipping. Where do we contact someone who can look at it directly?
Remove the motor cover. 2manyhobbies_1.jpgRun the treadmill and observe the operation. Try walking on the machine and again observe the operation.
There could be 1 of 3 things causing your problem.
1) the motor drive belt may be loose. Tighten or replace the motor belt.
2) the pulley may have broken free from the front roller. Drill a small hole through the pulley into the metal roller on the backside of the pulley, and drive a screw into it. (see picture).
2) the walking belt is too loose. Adjust the walking belt by the rear roller adjustment bolts.
I have also seen the drive pulley come loose from the motor, but that is very rare and unlikely..
If you need someone to service the machine, on the model/serial number tag is a phone number to the manufacturer. They will direct you to the authorized service company in your area.
Feb 02, 2011 | Proform Sport 1000 Folding Treadmill...
I changed the blade mandrel from my 42 inch cut craftman mower, I need to put it back together I need a directions on how to put the spring and pulley back on also I damaged the nut on the pulley, What...
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Oct 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck belt keeps tearing up then falling off
If it's an idler pulley, where the belt changes direction from the engine - yes it should turn freely. If it's a double pulley where the drive pulley from the engine connects with the deck/blade pulley, then it it's not going to turn totally free because of the blade pulleys connected to it. But in all cases, none of the pulleys should be seized. Try using WD40 or PB Blaster on the pulley bearing surface to loosen it up - or a new pulley...
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Proper Band Saw Blade
I was just on Sears website and if you go to the bottom of page you can link over to Sears Parts Direct and type in your model number and you should be able to get it online. Good luck
Dec 17, 2008 | Saws
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
41 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
