Question about Canon ZR200 Mini DV Digital Camcorder
Canon zr200 Gray lines
Out of no where I started getting gray lines across the screen. What is wrong? What can I do to fix it?
Change your resolution and it should go away.
Posted on Jan 06, 2008
Gray shades Everytime I scan a white sheet of
Try adjusting the contrast and brightness settings when you scan. If the contrast is set wrong it will pick up the shade of the white paper.
Sep 30, 2013 | Canon DR-3080CII Path-Through Flatbed...
Gray pixels create couple of blobs
I had the same problem on my SD870. I sent it back to Canon and they replaced the LCD screen for free under warranty.
Jun 23, 2009 | Canon PowerShot SD870 IS Digital Camera
When i play the video tape, the picture is like pieces of puzzle
that kind of happened to me, except there were gray horizontal bars going across my screen. I could only see half of what I was watching. Turns out, I just kept playing the tape and they magically went away. crazy but true. Now the only thing I need help with is getting the tape in it, as the camera won't take any tapes.
Jan 03, 2009 | Canon ZR200 Mini DV Digital Camcorder
My Cannon ZR200 was working good but now when I play back my dv tape there are 5 gray lines on my camera screen and the tv if I play back on the tv, I can play that same tape in my brothers camera with no...
It sounds like your saying the gray lines are appearing on your camera and on the tv when you play from the camera but not on your brothers camera. It sounds like your heads are dirty. Get a head cleaner and you should be good to go. Please take a moment to rate my solution fixya.
Thanks and enjoy,
Lee
Dec 07, 2008 | Cameras
Lines across the sreen when i play back the tape
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off.
Nov 25, 2008 | Canon ZR800 Mini DV Digital Camcorder
Gray lines across screen
You have a "head clog" more than likely...accordianman
Jun 10, 2008 | Canon ZR200 Mini DV Digital Camcorder
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
Cannot view tape playback.
I emailed my problem to Canon and this is what they sent me.
"As a first step towards resolving your issue, we suggest that you
restore the camera's default settings. You can reset all of the menu
and button operation settings to default except for Date/Time, Language,
and Video System. To reset these settings, please follow these steps:
1. Please remove the AC adapter and main battery.
2. Please remove the backup battery. It is located behind the main
battery.
3. Please turn the POWER SWITCH to camera, then to PLAY/VCR.
4. Then please turn the camera off for approximately 1 minute.
5. Please use a clean pencil eraser to rub the contacts inside the
battery compartment and on the battery.
6. Put both batteries back on the camera.
7. Connect the camcorder to AC adapter.
8. Clean the tape compartment with a dry tape head cleaner.
If the error is not cleared, we recommend you please send the camcorder
in for service."
You might have to do it twice and put a tape to try and record before it works perfectly. It worked for me so hopefully it works for you.
Nov 27, 2007 | Canon ZR200 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Gray Lines
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
Jun 10, 2006 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
346 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
