Question about GE Spacemaker Washer and Dryer Electric Laundry Center
I took two out of the three screws out of the center of the inside back panel of the dryer, and now cannot get them re-attached. something is unbalanced...help!
  • sporterinct Sep 27, 2009
    Yes, it was! Thanks Tom Zs!
    If you must know, I saw a big pile of lint back there, and with years of sub-par drying attempted to take matters into my own hands! you see where that got me : )
  • 220 Answers
First,why did you do that?Unplug the dryer,those screws hook the tub to the back bearing without,tearing the whole thing apart try this ,try to spin the drum around to where the remaining screw is at the top and roughly centered at the top,while moving the drum around for alignment purposes use a awl/center punch or even a piece of wire hanger pushed through one of the holes to re-align it and get the second screw in,once you get a second one in the last one is a piece of cake.And lift up on the drum as your turning it or you run the risk of bending or breaking the remaining screw.
 Once you get it back together we can tackle what brought you to this point....lol
Posted on Sep 27, 2009
Can u help me please we're do the brown grey and white with pink line wires go
Four-Wire: Green
The green wire is the ground wire, and it is the difference between a three-wire and a four-wire cord. (In the three-wire system, the ground wire and the neutral wire are the same.) The green wire connects to the dryer frame. Look at the cord-connection terminals on the back of the dryer. Very close by, you should see a screw sticking out of the metal panel. It will be labeled "external ground connector" or something similar. Connect the green wire to that screw.
Four-Wire: Black
Most appliances in your house run on 120 volts of electricity, some on 240 volts. The dryer needs both--240 volts to run the drum and heating element, and 120 volts to run the timer, thermostat and other components. For this reason, the dryer cord has two live or "hot" wires--one black, one red--rather than a single hot wire. The dryer draws 120 volts from each hot wire to get the 240 volts it needs for the heavy work, then pairs one hot wire with the neutral wire for the 120 volts to run the smaller functions. Look again at the connection terminals on the back of the dryer. There should be three screws in a horizontal row. Connect the black hot wire to the terminal on the left.
Four-Wire: Red
Connect the other hot wire, the red wire, to the terminal on the right. (In truth, you could connect either hot wire to either hot terminal, but it's standard procedure to put the black on the left and the red on the right, so do so.)
Four-Wire: White
The white is the neutral wire, and it connects to the center terminal. There may be a metal strap attached to this terminal. That's a ground strap. When a three-wire cord is attached, it serves the same function as the ground screw mentioned above.
Three-Wire: Gray
If you have a three-wire cord, then all three wires will be gray. They're arranged side-by-side with the hot wires on the outside and the neutral wire in the middle. Attach the hot wires to the left and right terminals and the neutral wire to the center terminal. Make sure the ground strap is attached to the center terminal.
Nov 20, 2012 | Dryers
My DeLonghi DSM800 when running sometimes stop for a second and then starts up again. It also seems to speed up at times and almost sounds like it is skipping a gear or something. Any ideas.
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 03, 2010 | DeLonghi 800 Watts Cucina DSM800 Stand...
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
The heating element( I'm guessing) inside the dryer, behind the panel with the 3 screws got really red hot and smelled of smoke. I have a gauge thing from the hardware store to check to see if the heating...
last thing u wanted to do was remove the three middle srew they hold the drum .
u are going to need someone else to help,first try to reinstall the srews .
after reinstalling
top left back there is a thermal fuse this fuse goes when the element goes element about $95.00
fuse 13.00
under neath the panel next to timer 1 black screw on other side 1 more screw remove
remove casing with both timers.more screws
un clip all wire harness
all screws on top off
look at belt remember how it came off
now remove front panel
remove belt
push up drum hard
remove drum
now u can get too the heater
best of luck al
May 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Dryer no heating how do I get to the fuses and the heating elemet
using a wide flat screw driver pry the top up at the edges betwenn the main top and the front panel. Lay it down on it's back for this. Now look for your door switch wires and undo them. Now look inside the front panel toward the top and remove 2 attaching screws or hex screws. Lift panel at top and remove. Now undo 3 screws in middle of inside drum and pull drum out after un-doing belt. There you should find your heat element and all the thermostats and the thermal fuse should be labeled. If heat element is not broken then chances are your thermal fuse is bad replace it
Feb 28, 2009 | GE DVLR223 Dryers
Lint is collecting inside the housing not exiting via vent.
you would need to remove screws holding on the door as well as the opposing screws , after remove th edoor the front "u shaped" panel will pull foward and off, yo may be able to acess the venting from this point
Jan 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
Electric Frigidaire Dryer Model GLER341AS1
there are two tabs that hold the top cover on,they are a couple inches in from each side.push in and lift lid. inside front panel are two screws, remove them then pull front cover out and lift it up of tabs on bottom.once you get the cover off remove belt,the you will be able to see your mess. heating element mounts to back panel.there is a heat sheild that mountws to the back of the drum.then you lift the drum up and put three screws in the drum to the pivot plate on the back panel.
Apr 21, 2008 | Frigidaire GLER341A Electric Dryer
GE Electric Dryer
that is one thing I have learned, don't take anything apart that you dont need apart. Clean with shop vac-it will suck it out.
Jan 04, 2008 | GE DWXR483EBCC Electric Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
