Question about Toshiba 50HP66 50 in. Plasma Television
My Toshiba 50HP66 Plasma TV entire picture dims slightly every 30-50 secs while viewing regular HD cable. A 33" wide shaded area from top to bottom also appears in the center of the screen simultaneously. The picture will then go back to normal brightness/viewing. I have reset back to factory settings, reset my cable box, disconnected /reconnected all cables to and from the TV. The problem persists. It's as if there is a megahertz (mhz) setting issue like on a computer monitor. Any ideas?
    Top Expert:
  • Toshiba Master
  • 23,616 Answers
Could be copy protection like we had with video tapes.
Posted on May 23, 2017
2 Suggested Answers
SOURCE: cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Posted on Jan 20, 2009
Toshiba 50HP66 Plasma TV Problem - TV comes on but no picture. OSD shows up as vertical stripes on black background. picture sometimes black, sometimes multi-colored verticle stripes. Should I change the...
Generally this problem is in your signal board. You may also know it as the scaler board, as you mentioned. I have not repaired this particular model. But I would first suspect the the signal board (scaler). If you are not sure what this is, it is the board with all the RCA Jacks and RF connections. The problem in this area are bad or failing capacitors. Thanks for asking and show all hands of support!
May 02, 2011 | Toshiba 50HP66 50 in. Plasma Television
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Is there a hope for a Toshiba 50" plasma TV which
Hi, it sounds like the lamp is on its way out. Depending on the size of the television, it may not be cost-effective to try to have it repaired. If it's under warranty, then contact either the manufacturer or the place where you purchased the TV, and find out what your recourse is. If it's out of warranty, however, there is a good chance that fixing it will cost 60% or what it would cost to purchase a new one.
Mar 27, 2011 | Toshiba 50HP66 50 in. Plasma Television
5 year old TV 50HP66. Heard two pop/cracks from the back of the TV. Picture got dim and grainy. Wont go back to a clear crisp picture. Please advise.
Are you comfortable with opening up the TV after it is unlplugged? If not, then I would advise finding a local repair shop. It is likely that a capacitor and/or other parts overheated and blew. Caps are supposed to blow once they become too stressed. However, a bad cap could also be a sign of other problems as well.
Mar 23, 2011 | Toshiba 50HP66 50 in. Plasma Television
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
Cannot optimize picture width on new flat screen HD
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Sony DVD connected to HD system used to be regular colours, now it only shows shades of pink. .
dvd format must be compitable with tv-if it is compatible change your video cable with new good brand one from (radio shack)or any electronic store near you.
Jul 04, 2008 | Denon AVR588 Receiver
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Toshiba 50HP66 50 in. Plasma Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
