Question about HP Pavilion dv6-1030us Notebook
How do I replace a keyboard on a HP dv6-1030us?
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
    President:
  • 2,600 Answers
  • hershey49913 Jun 30, 2010
    Thanks so much dude!!!!
    Problem Solver:
  • 16 Answers
Prepare a new keyboard, you can find it via this website:
http://battery-adapter.com/product_info.php/products_id/3674
Turn the notebook over so that you are looking at the back. Pull the battery latch to the left to release the battery. Remove the battery from the notebook. Make sure that no cables are still plugged into the notebook.
Remove between three and six screws, depending on your model of HP Pavilion, in the cavity where the battery sits. Also remove any screws in the middle of the back of the notebook. Most notebooks will have a small keyboard icon next to the screws you need to take out, but if your screws are not marked, just take all the ones in the middle of the keyboard out. You won't hurt anything and can just put the screws back in later.
Turn the notebook over and open it up as far as it will go. Take your flat-head screwdriver and get it behind the switch cover. The switch cover is the piece of plastic between the keyboard and the hinge, running across the top of the keyboard. With your screwdriver behind the switch cover, press away on the screwdriver to pop the cover out of place. You can locate and unplug the cable that connects the switch cover to the motherboard, but it is unnecessary. Simply place the switch cover back above the keyboard, but shifted up about 1 inch.
Remove any screws that were hidden by the switch cover. If you had to remove several keyboard screws on the back side of the notebook, there might not be any screws here, but if you only had to remove one screw from the back, there can be up to three screws here.
Pull up on the back of the keyboard until you raise the keyboard to about 30 degrees. Then pull the keyboard toward the screen to release it from under the housing.
Tilt the keyboard up and find the cable that connects the keyboard to the motherboard. Pull up on the connector, or if the connector has latches on its side then push back on the latches, and slide the cable out of the connector. Remove the keyboard from the Pavilion notebook.
Slide the cable of the replacement keyboard into the slot that you just removed the old cable from. Flip the lid of the slot closed, or push the latches in, to lock the cable in place. Put the bottom of the keyboard in place while keeping the keyboard tilted at about 30 degrees. Once the bottom of the keyboard is in, tilt the keyboard down and replace any screws that you had removed.
Push the switch cover back into place and push down to lock it. Turn the notebook over and replace any screws that you removed.
Posted on May 08, 2011
  • 339 Answers
Look on the bottom of the computer. There should be two or three screws with a keybooard like icon next to them. Remove or loosen these screws.
Next, look at the top of the keyboard between the various "F" keys. There are usually four sliding latches that you need to push towards the front of the keyboard approximately 1/8" usiing a small flat bladed screwdriver.
Now, gently pry the keyboard out from near the latches. There will be resistance from some double stick tape on the bottom of the keyboard.
Finally, loosen the connector(s) for one or two ribbon cables. Gently pry the plastic top up and then remove the cable.
Re-assembly is the reverse.
Posted on Oct 01, 2009
crok41
  • 621 Answers
SOURCE: How do I remove the screen? I don't see any
After you lift the screen you will see 3 or 4 smallrubber plugs at the top and 2 at the bottom, if you have fingernails they come out easily if not a small flat screwdriver. You will now see the screws now just gently work your way around the screen and it will just clip off........cheers from Scott
Posted on Apr 20, 2010
  • 1082 Answers
SOURCE: how do i replace the lcd screen on hp dv6 1030us i
Generally the keyboard is removed first then you can tackle the LCD. I'm surprised you are replacing it as LCDs are expensive.
Posted on Aug 13, 2010
Justintechno
  • 36 Answers
SOURCE: hp dv6 - 1030us. very
Look are a key that says "fn" on it. Hold that key and press F8 to turn up the screen brightness.
Posted on Aug 03, 2011
Matrix12
  • 370 Answers
SOURCE: MY HP DV6 1030US will
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Posted on Sep 14, 2011
ratheeshmoha
  • 349 Answers
SOURCE: I have an Hp Pavilion
installing webcam driver
Posted on Sep 23, 2011
How do i replace keyboard on hp pavilion model no 15-n278sa
Watch these youtube tutorials
https://www.youtube.com/watch?v=GUzBWFqTKwM
https://www.youtube.com/watch?v=FeJAyYM51QQ
https://www.youtube.com/watch?v=IdjVDB3FCDA
Get more from google search
replace keyboard for HP Pavilion laptop
After you've do you feel you are technically proficient to replace a keyboard?
Be careful. Someone I know, who believed that changing a keyboard is piece of a cake, had to take his keyboard parts and laptop in a shoebox to a repair technician
Feb 20, 2015 | HP Computers & Internet
How to change a HP 8460p keyboard
You maybe able to get a replacement keyboard from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Mar 10, 2013 | Computers & Internet
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Replacing the keyboard on a hp g60 127nr
Take the battery off and there are 3 screws with a picture of a keyboard next to them. remove them and then lift up the keyboard from the top and carefully pull it out. Be careful because it is still connected to the laptop, remove the connection. there are 2 push clams one on the left and one on the right of the connection strip. after you remove that your ready to go.
Jul 09, 2010 | HP G60-127NR Notebook
Replacing hp dv9700 keyboard
Look for the screw marked with a keyboard icon and removed them then you should be able to remove and replace the keyboard. Not too hard. You can get the service manual from HP if needed.
Mar 09, 2010 | HP Laptop Keyboard for HP Compaq Pavilion...
My sons hp keyboard will not work
Hello janene hi, you can check your son's HP keyboard, by testing the keyboard on another computer, just make sure the PC is off when you swap the keyboard, if the keyboard malfunction, replace the keyboard with a new one, we don't usually repair the keyboard, after market keyboards are available cheap.
Nov 21, 2009 | HP DC170B Keyboard
Replace HP dv9000 keyboard
This is probably the closest model to your HPdv9000, click on the link and read on! http://www.insidemylaptop.com/remove-keyboard-replace-memory-hp-compaq-nc6400/
Good luck and have fun!
Dec 03, 2008 | HP Pavilion dv9000z Notebook
Keyboard replacement on an HP 8333 Laptop?
If you look on Google, there are sites that have step by step instructions on how to do it.
Jun 14, 2008 | HP Laptop Keyboard for HP Compaq Presario...
HP Pavilion dv6-1030us Notebook Logo
1,721 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
