Question about Maytag Dryers
I have a Performa Maytag dryer and the hot air stopped working. When we pulled it out to troubleshoot, we found a lot of lint and a bird (dead). Didn't seem like he'd been there long, but after thouroughly cleaning it out and replacing the duct for hygenic purposes, we still can't get it to work...is it possible theres a pilot light and if so, where can we find it? thanks! Marie and Ryan.
  • marie_hirsch Sep 27, 2009
    It's model# PYGT2444AWW
    Are you still there?
  • Maytag Master
  • 3,361 Answers
Marie? What is your model number?
Posted on Sep 26, 2009
  • steve
    steve Sep 28, 2009
    Check the glow bar ignitor at the gas valve,is it working. If not,replace the glow bar ignitor. If the glow bar ignitor is working,replace the gas valve coils.
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Dryer gets hot, but stays damp inside and clothes don't dry. I removed a birds nest from the outer end of the vent, and there is plenty of hot steamy air coming through, but still having this problem....
The vent is probably still stopped up. You are going to have to pull the dryer out and disconnect the 4" vent hose from the back and inspect the vent all the way through.
May 18, 2011 | Dryers
Maytag performa gas dryer appliance gets hot but have to cycle clothes 2 times to get dry, have vacuumed out lint trap and exit vent any ideas thanks.
Hi, it sounds like you have covered most bases. One other thing I would check is total airflow. Outside, where the dryer exhaust leaves the building it should be unobstructed, If there is a flap or louvers they should open freely. You should be able to feel the warm air when you put your hand at the vent. If aiflow is good, the thermostat may be defective.
Feb 02, 2010 | Maytag Dryers
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
My dryer gets very hot and shuts off
Your hot air discharge piping is probably stopped up with lint. Take all the piping off and check everything, straights, elbows, even the discharge grill outside your home. It's a little more work but I would take the rear panel off the cabinet and take a vacuum cleaner and clean all around. Make sure you remove the power. If it persists after a good cleaning, it could be a bad limit switch (thermostat) or an operating switch (thermostat). These are round switches with metal (wings) for screws that have two wires. Look on the diagram on the back panel on most machines. GOOD LUCK.
Aug 25, 2009 | Maytag Performa PAV2200
I have a May Tag dryer which blows the Thermal Fuse.
I am not 100% sure, but I think that the model that maytag had with that dryer. When I was working for my local dealer I had to change several of those, and it about 2 weeks time they blew.
Aug 09, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
