My laptop Hi: my wife was cleaning out her laptop and blowed off all kinks of stuff, now she has no sound.
  • alfhild Jan 08, 2008
    I have no sound from the internal sound card---I am using a usb sound card, and it works fine----On occassion I will get some sounds from the laptop without the usb card, usually startup windows music, but recently i had muted and distorted wave music---I couldn't get it to improve and rebooted---the sound disappeared and i couldn't get it back..
    When the problem first appeared, i did live chat with gateway--they concluded that I would have to send it in---$150 and probably a new motherboard---I took it to a local computer guy and he suggested the usb---I wonder if there might be a bad connection between the motherboard and a separate audio card---I have tried loading new drivers, etc----because i on occasion get sound from the laptop speakers, i suspect a hardware problem
    thanks perry mcfarland
  • 556 Answers
It will take information about the manufacturer and model of the computer and the operating system to find the appropriate drivers for download. Meanwhile have you checked the sound control panel to assure volume did not get muted or other settings changed?
Posted on Dec 17, 2007
Str-w770 stereo amp
It could be just a lead, check your lead heads and inserts are clean.
Check along your leads and wires for any obvious kinks / tight bends / cuts / nicks / something sitting down on it or any damage to the wires.
It could be just the dials / knobs need taking off and cleaning in behind. the pickups, you may not need to remove them just spray with electronic cleaner b3203b06-4ced-4fda-befd-44f385f97b7e.jpg this stuff is great for lots of differnts electrical cleaning problems.
Good luck
Feb 09, 2014 | Sony Audio Players & Recorders
My wife has a Compaq CQ57 she cooked her old hard drive, and we replaced it, put windows on it, and all the drivers. But she keeps having an issue of her laptop going to sleep in the middle of her doing...
Compaq laptops are notorious for overheating. I would suggest the following:
- Use canned air and liberally blow out all the vents on the laptop. Remove the battery and blow air into the CPU vents to clear out any debris from the heat sink.
- get a laptop cooling fan base (typically USB powered) and use it every time you get the laptop out. This not only helps with venting but it raises up the laptop so, if it is used on your lap/couch/blanket, it will ensure the vent is not unintentionally blocked. (My wife did this - used the laptop on her lap when she had a blanket under it. Blocked all the vents and burned it out in less than 3 months.)
If the issue still continues, the damage may be deeper and could involve replacing the CPU heat sink assembly.
Hope this helps!
Nov 09, 2013 | Computers & Internet
Compaq cq-45 laptop light near to caps and scroll blinks , No display
In Most cases this happens when using Nvidia graphics.
You need to open your laptop - call a technician for professional Job is you are not able to do so.
After removing the cooler which usually comes with a small fan (covers the main processor), remove the processor and you will see a chip that need a "HOT AIR STATION" this tool blows very high temperature of air on the surface.
well I used my wifes Hand Hair Dryer - also does the magic.
see image on where to blow the hot air.
now after blowing the hot air, mount your laptop again.
but first, let it cool down.
Sep 04, 2013 | Compaq Presario CQ-45 Laptop Universal AC...
How do i put the sound back on my computer?
What is the OS on your computer?
What excatly did your wife delete?
Jan 08, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
Washer pump working, no washer fluid reaching window, refilled washer bottle already
sounds like the water hose is kinked or the outlet ( inside the reservoir ) is blocked. also check to see if the spouts are blocked with dirt and stuff,, ( could be a blockage at the 'Y' fitting ). if you disconnect the line from the pump you should be able to blow air through to check flow to the spouts/sprayers.
Dec 29, 2010 | Hyundai Santa Fe Cars & Trucks
My washer no longer cleans the dishes. the functions all work but it appears that the pump pressure is too low to get stuff off the the dishes.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
Sep 06, 2010 | Bosch SHU9925UC Built-in Dishwasher
Poor cleaning
I found a lot of stuff built up in the spray arms and replaced them...wife is happy again... :-)
Here is a tip that I wrote about your problem...
Apr 17, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Format the laptop
Several Problems.
First, sounds like you need to reinstall your operating system. Place your original system disk in. F8 to be sure that it starts from the CD. Be sure to "Press any key to start from CD". At that point you can either repair or reinstall your operating system. Repair will be not destructive to your data files. Reinstall will reformat your drive before reinstalling.
Your keys not working could be a number of things. A broken key requires keyboard repair or placement while dirt or grit can give the same symptoms. Try cleaning with the computer off...Blowing air around the problem keys. Be sure to use clean air, the canned stuff. Try not to blow the dirt under another key.
good luck
Feb 22, 2010 | Toshiba Tecra M1 Notebook
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keyboard error
new keyboard, or remove this one, and blow it out with compressed air. sounds like there's some stuff under some of the keys.
got backup for the Dell?
Feb 19, 2008 | Dell Latitude 110L Notebook
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
