Question about Maytag Dryers
I have a gas dryer,theunit is not heating up all the time,like the gas isn't igniting pinnco@ymail.com
  • Maytag Master
  • 3,361 Answers
Replace the gas valve coils. It will work fine then.
Posted on Sep 26, 2009
I HAVE A KENMORE DRYER, MODEL # 110.78652700 AND THE BURNER DOES NOT IGNITE. DRUM TURNS BUT NO IGNITION. ANY IDEAS?
check to see if the ignitor is lighting,, if it is,, then you need the coils replaced, on the burner control,, this link shows where they are http://www.applianceblog.com/mainforums/sears-kenmore/17748-kirkland-gas-dryer-no-heat.html if the ignitor isn't glowing,, replace it
Aug 22, 2011 | Dryers
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
My dryer is only blowing cold air
Is this a GAS Dryer? Or, an ELECTRIC Dryer?
If this is an ELECTRIC dryer, and your dryer runs, but does NOT heat, you more than likely have a problem in the heating circuits. Any one of the following could be causing your problem:
1. Heating Element
2. Thermal Cut-Out (TCO)
3. Hi-Limit Thermostat
4. Improper input line voltage
5. Defective power cord.
The following link explains how to troubleshoot and diagnose a no heat problem on an electric dryer:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If this is a GAS dryer, the most common failure for heat related problems is a weak or blown igniter on the burner assembly.
It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite. If you are expriencing longer ignition times, the igniter probably needs to be replaced.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
You can purchase replacement parts (if required) at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance to assist you in locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this can help you.
NOTE: Repairclinic.com has a repair manual that you can purchase that will help repair any Whirlpool manufactured gas or electric dryer (such as Roper). The part number is 1159257.
Aug 17, 2010 | Kenmore Dryers
My roper dryer is not heating.
1. Heating Element
5. Defective power cord. The following link explains how to troubleshoot and diagnose a no heat problem on an electric dryer:
repairclinic.com
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this can help you. NOTE: Repairclinic.com has a repair manual that you can purchase that will help repair any Whirlpool manufactured gas or electric dryer (such as Roper). The part number is 1159257.
May 13, 2010 | Dryers
DRYER RUNS BUT NO HEAT
If this is an ELECTRIC dryer, If your dryer runs, but does NOT heat, you more than likely have a problem in the heating circuits. Any one of the following could be causing your problem:
1. Heating Element
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
May 12, 2010 | Dryers
No heat
1. Heating Element
repairclinic.com
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Mar 22, 2010 | Dryers
Electric clothes dryer stopped heating
1. Heating Element
repairclinic.com
Mar 21, 2010 | Dryers
It's not putting out any heat to dry the clothes.
Is this a GAS Dryer2_bing.gif? Or, an ELECTRIC Dryer?
1. Heating Element
repairclinic.com
Mar 18, 2010 | Whirlpool Dryers
Dryer spins only cold air
If this is an ELECTRIC dryer, the following link will give you some advice on how to troubleshoot a no heat problem:
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly.
It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite. If you are expriencing longer ignition times, the igniter probablt needs to be replaced.
repairclinic.com
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 28, 2010 | Dryers
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
