Question about KitchenAid Dishwashers
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
Have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Posted on Nov 04, 2010
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
There is residue left on dishes after wshing and a whitish film on the dishwasher door. Looks like mineral deposits. My rinse aid dispenser has stopped working as well. Could this possibly be solved by...
heatman101';;'';
Apr 03, 2011 | KitchenAid 24 in. KUDS25 Built-in...
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
    You have to buy a cartridge type water softener and attach it to the
    inlet water line of your dish washer. In addition to this there must be
    a salt compartment in the dish washer.
    Refer the user guide /owners manual and locate. Fill it with the special
    dish washer salt. ( Do not use kitchen salt used for food).
    The dish washer salt may help to certain extent in softening the wash
    tub water inside. Check the switch settings for rinse aid and salt
    release settings in the machine. Refer manual!
    Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
    Detergent is left undisolved in bottom of washer when cycle is completed. Water pressure is correct. No cloged pipe. What is happening? No excess detergent. Kitchen Aid dishwasher. Imperial 21 series
    I have the kitchenaid KUDK03CTSS3 dishwasher with the same problem, it doesn't take the detergent. Have you been successful in finding a solution?
    Jul 07, 2010 | KitchenAid Dishwashers
    Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
    Hi.
    Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
    Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
    Ensure that the drain well is clean.
    Ensure that spray arms have enough pressure, check water level and impeller pump.
    If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
    The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
    Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
    Dishwashers Logo
    247 people viewed this question
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
