Question about Homestead Liquid Propane Gas Patio Heater
I need to refill a smaller gas bottle from a larger one and have never done it before. please help me.
    Champion:
  • 274 Answers
Hi, i'm thinking about getting a gas dryer but the only gas available are the 20lb. LPG portable cylinders.Will this be able to work a gas dryer?if yes,can you help me decide on which type and brand i...
While there are several gas dryers that will work on LPG by changing the size of the orifice, I would not recommend the use of 20 lb bottle inside a house. LPG is heavier than air so it will accumulate in low areas, so presents a safety hazard.
In the state of Colorado, if I put an electric or natural gas dryer in a mobile home I don't need any special permits or preparation. BUT if I put a LPG dryer, heater, stove in a mobile home, I need special permits AND a trench to move the heavier than air gas from under the trailer and away from the structure. AND that is with the LPG tank being more than 50 foot from the structure, not in it like you are planning to do.
So the answer is yes, it can be done. But it SHOULD NOT be done!
Jun 30, 2011 | Dryers
On the 1989 Toyota Corolla with air cond., whitch side is the refill side to introduce a can of r-12? The smaller or larger hose side? Should the refill be done with the can upright-as a gas or upside down...
Your recharge hose/kit will only fit one side - check the fittings, and to answer your other question can should be upright so you fill with gas. Turning it upside down you have the chance of over-filling and blowing seals when freon expands.
Feb 21, 2011 | 1989 Toyota Corolla 2 Door
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
How do i remove the bit from the drill
This drill has a 2-level chuck handle. one is slightly larger diameter, or is closer to drill body. It is fixed to the motor shaft. Smaller diameter, or forward one is the adjustment. Hold the rear/larger one stationary and twist the smaller/forward one as if you were opening a water bottle with a really tight lid.
Sep 17, 2010 | Black & Decker 3/8" Variable Speed...
HOW TO REFILL INK
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
After you have refilled the inks make sure you know how to reset the inks after or it will still show emty, you need to find the codes,
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | HP PSC 1510 All-In-One InkJet Printer
Locating the High side and Low side AC gas ports
Easy. find the compressor. The larger hose attaching to the compressor is the "suction" side. This is where you install the refrigerant.
The smaller hose, whether rubber or metal as it travels to the passenger compartment, is the high pressure side.
After installing refrigerant and as the compressor is running, the larger hose will feel cool and the pressure side will feel hot.
Jul 29, 2009 | 1998 Dodge Caravan
Is the A/C low side port at the firewall, passenger side?
the low side ac valve, should have a blue cap. and is the smaller of the 2 valves. that smaller one is what you would need to use to refill the system..if you are planning on refilling the ac, make sure the bottle you get to refill with is the right fluid... some earlier cars still run on r12, and some run on r134a. if you are going to fill it, have the car running and then check the pressure before you add any fluid cause you will mess the system up adding to much... hope this helps you..
Jun 11, 2009 | 1999 Pontiac Grand Am GT
Im looking for the por`t `to charge my a/c system in my 2005 dodge darango
on the bottle you bought to recharge it is it r134A? r12? cause you need to check under the hood first look for the sticker that should be on the hood that says R and will have the number of the fluid to use... then the connector they have on the end of the right bottle will only fit on one of the openings, it will be the low input side you need, it is normally a blue capped valve, if you dont see that, then look for a black valve cap. the bottle or refill fluid will only fit on the right one... it is the smaller valve opening... if you see a larger valve opening then what is on the refill bottle that is the high input.. YOU NEED LOW INPUT... refill it while the engine is running... but first with the engine running check the pressure level... DO NOT OVER FILL you will ruin the compressor, and need to bring it to a shop to get it fixed... refilling of the a/c you should know the ambiant temp. (temp outside at the time you are doing this) and what your current pressure is.. if it is below put some in... ONLY ADD FLUID WHILE TRUCK IS RUNNING... CAUSE YOU WILL OVER FILL IT IF IT IS NOT RUNNING AND BREAK STUFF....
Mar 17, 2009 | 2005 Dodge Durango
What type of tiller
# Gas vs. Electric * Some smaller models are electric. o Limited range based on length of extension cord. o Electric doesn't have the same amount of power as a gas-powered motor. * Most of the larger models are gas-powered. o Gas-powered machines are more powerful. o Keep in mind that gas-powered machines require more maintenance, including refueling, engine fluid changes and refills, and winterizing in cold climates.
Aug 27, 2008 | Mantis Tiller
Power Source Problem
# Electric leaf blowers are lighter, quieter and vibrate less than gas units. An electric motor drives the fan, so there's no need to mix fuel or refill. Smaller yards are especially good candidates for electric blowers. There are two types: * Corded leaf blowers provide constant power as long as you have access to an electrical outlet. The attached cord limits mobility so this may not be the best choice for a lawn with lots of trees. Look for a cord retention system to prevent the cord from being accidentally unplugged during use. * Rechargeable/battery-operated leaf blowers are good alternatives for smaller areas or jobs. They work well on solid surfaces like driveways and garages. They're limited by their run time and the fact that they move less air than larger models. # Gas-powered leaf blowers use a 2-cycle engine, requiring mixing oil and gasoline. Mobility and work output are increased with gas blowers. They're louder and heavier than electric blowers.
Aug 27, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Homestead Liquid Propane Gas Patio Heater Logo
51 people viewed this question
Top Homestead Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Homestead Pool and Spa Expert? Answer questions, earn points and help others
