Question about OKI C5150n Led Printer
543:K toner sensor error. How do I fix it? - OKI C5150n Led Printer
    Novelist:
  • 125 Answers
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Posted on Sep 27, 2009
Testimonial: "Thank you very much! The toner cartridge was fine, it was the sensor that was dirty and I was able to clean it with a Q-tip. I appreciate your help."
  • hefy_jefy Sep 08, 2010
    Woot! fixed it - been driving me nuts - put a new cartridge in and it still gave a low toner warning.
    Thanks
SOURCE: 543:K toner sensor error
Hi people,
we had the same problem and tried the above method, it didn't do the trick for us, but we went a bit further.
The place described with the little white plastic (under the blue lever) we took the little plastic plate of and cleaned the whole inside (the sensor is in there a, little hole). Put the plastic plate back and that was it. Hope if the above doesn't work, this will.
Posted on Oct 17, 2008
SOURCE: 543 K: Sensor Error
I had the same problem, after lots of work and fooling around..............Place a piece of white paper in the window where the sensor looks
Posted on Jul 25, 2008
  • 95 Answers
SOURCE: toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
Posted on May 03, 2009
Soulvisitor
  • 1113 Answers
SOURCE: Check toner cartridge
Yes to non OEM's and those of you who are using them they cause heap em troubles.
It can be the drum they sit on, or toner dust on contacts of drums, machine base, and toner cart sides , also machine has eyes that get dusty, on machine frame at every toner/drum.
Pull out a tonerlook at side of handle there is a rectangle cut out silver/or black inside this lines up with "eyes" in side of printer frame, clean em.
I have also found a lot of import oki toners going around causing grief too, but fix is always sucessfull by A new gen non import toner and drum and ensuring contacts are free from toner dust.
Another thing I find customers doing is not replacing toners when machine requests them ie at REPLACE TONER, instead they find that just openning and closing lid keeps them going, but these machines hold a complete toner in the drum unit too, so all they are doing is depleting that and when they do finally provide a toner it goes straight into filling up the drum and therefore shortly will display repalce toner again.
Signgirl - your using OEM's so I suspect drum/contacts/eyes what % are t drums at and are they oem too?
Wendy - dont recommend aftermarket/refills all the money you save will be paid to someone like me to come and fix the problems they end up causing.
OKiproblem - ever use aftermarket carts/drum, and what are % of consumables?
Posted on Dec 20, 2007
  • 4 Answers
SOURCE: Oki Printer c3200 error code
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Posted on Oct 27, 2008
I received a message "543:
this means that the toner chip on the black cartridge is defective and theres really nothing you can do other then get another black toner to replace it with. some companies do sell the chips but probably easier to return where you bought it and get a new one to replace it. The company ,if reputable shouldnt charge you for another one but just exchange it with a working toner... Please mark as FixYa! if this helped...Get Paid To
Aug 04, 2011 | OKI C5150n Led Printer
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
I have replaced the toner cartidge and it is displaying 543 sensor error on my OKI 550
take a look here :
http://www.c5200.co.uk/index.asp?menumode=0&content=sensorerror
Oct 13, 2009 | OKI C3200n Led Printer
Toner sensor problem k toner 543
May 03, 2009 | OKI C5150n Led Printer
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Sep 01, 2008 | OKI C3200n Led Printer
543 K: Sensor Error
Jun 18, 2008 | OKI C5200n Laser Printer
Message to order new k immager
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Mar 09, 2008 | OKI C5200n Laser Printer
Toner sensor error
Feb 11, 2008 | OKI C5200n Laser Printer
Dec 12, 2007 | OKI C5200n Laser Printer
OKI C5150n Led Printer Logo
3,537 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
