Question about RIM BlackBerry Storm 9530 Smartphone
Turn on ring
How do I turn on the phone ring tone on my blackberry storm?
krishrupin
SOURCE: Ring tone for Blackberry Storm
my mobile e 61i softwear change aney problem
Posted on Mar 26, 2009
SOURCE: Verizon Blackberry Storm
I have the exact same problem consequently all my calls go to voice mail ... very frustrating and just started happening in the past month.
Posted on Apr 12, 2009
  • 50 Answers
SOURCE: Blackberry Storm Screen
 There is a Blackberry Repair Guide that shows how to open a Blackberry 8900 Javelin and the storm is very similar. Check for any loose connections inside, otherwise you may need a new screen. Once it is open it's as easy as taking the broken screen off the front assembly and installing a new one, the parts are available on ebay. There are also third party blackberry repair services that will do this for you if you aren't covered under any other warranties.
Posted on Jun 10, 2009
dlemora
  • 9 Answers
SOURCE: Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Posted on Apr 24, 2010
SOURCE: Black Screen On Blackberry Storm 9530
Try to leave the battery out for an hour or two. Then try again. If it still doesn't work, it might be the lcd screen is damaged or its the software problem.
Posted on May 11, 2010
I just got a verizon b.b. 8703e and I can't figure out how to turn on the ring tone
A ring tone can be set for specific contacts on a BlackBerry smartphone that has 32MB or more of flash memory.
To set a ring tone, follow the steps below:
1) Click the Address Book icon on the Home screen
2) Select the contact that a custom ring tone is being added for.
3) Press the Menu key and click Edit.
4) Press the Menu key again and click Add Custom Phone Tune.
5) Select the ring tone from the list of available ring tones.
6) Press the Menu key and click Save.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Got a new Blackberry Storm and my ringer won't ring
Check either your profile or under "Options" -> "Sounds and Ringer Tones" and see if your volume is set to "Silent". Change volume to something other than "Silent" and see if your ringer works then.
Oct 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
I need the defaut ring tones for the blackberry storm. mine were accidentally deleted
First take a back up of the files on your PC or laptop,after backup reload the OS.To Relaod the OS select Application loader and install the new OS.
Aug 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm lock
i have a blackberry storm myself and mine doesnt do that when its locked. if you click on the sounds option and scroll down it says set ring tones/alerts and it will let u pick the sound type to check if its on a sound or vibrate other than that you might want to call the store or check the website it could be your phone.
Jun 15, 2009 | Cell Phones
How can i move music to ring tone file
You don't need to move the music tone to a ring tone file in order to use it?!
You can edit your profiles, when choosing the ringtone for any feature i/e phone - Browse, which will show you all tones including your music folder and it will allow you to choose any saved music tones here
May 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Mar 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Feb 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do I set a ringtone for ALL contacts
Go to the ringtone or music and Open Menu then select Set as Ring Tone!
Hope this can help.!
Best regards,
Julio de la Cruz
Jan 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
71 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
