Question about Frigidaire FRT21H8 Top Freezer Refrigerator
My feezer builds up ice at the back on the bottom
My freezer builds up ice at the back on the bottom right. nothing in my freezer is freezing, I've tried unplugging it to thaw it out (12 hrs) and ice continues to build up.
    Problem Solver:
  • 7 Answers
That is one of the symptoms of a failed blower fan. Typically on Frigidaire it's behind the metal shield with the thermostat knob at the back of the freezer. Go to an online parts place and look at the diagrams. To see it the fan is failed. Unplug from the wall, remove the shield, if you have an icemaker remove the two screws holding it on the wall and it's connector, then plug in the wall and either check for voltage or watch to see the fan spin.
Posted on Sep 26, 2009
Hot point side by side, back of the freezer inside by the fan keeps building up ice and freezes up the water tube for the ice maker, it will build up enough to hit fan.
if there's ice on the inside back wall of the freezer you have a defrost problem.i need the model number so i can help you.open the fridge door,look up on the right hand side up near the ceiling and you'll see a tag with the number,if it's older look down near the bottom hindge near the kick plate
Feb 02, 2011 | Hotpoint Refrigerators
Hello I have a GE Profile with Brita refrigerator bottom freezer and it suddenly stopped cooling in the refrigerator portion. The freezer works but very weakly. Ive unplugged it, let it go for one hour,...
The drain is frozen up. The fan what provides the cooling air for the fridge is stuck in the ice. Remove the vegie crisper and pop the bottom under the crisper s out. Also remove the Styrofoam plate. You will see the problem right in front of you. Use a hairdryer to get rid of the ice build up. Good luck
Dec 07, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer is freezing up.
Is the fridge getting warmer at the same time? How cold/warm do you have the adjustment set? Have you removed the far rear panel of the freezer? Behind the far panel you will see the defroster unit. Make sure it is not frozen up or that could be the defrost heater or timer may be bad. There is also a vent that goes from freezer to fridge, ice can build up in there and cause the majority of the air to stay in the feezer, you should clean out the blockage. I use coat hangers and screwdrivers myself to break all the ice free.
Sep 02, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
The freezer freezes up and no air circulates to the refrigerator. The Fan motor is working.
is there frost on the inside back wall in the feezer you have a defrost problem. a bad door gasket will cause the duct from the freezer to fridge to fill with frost so the air cant get to the frige
Dec 25, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Slimline feezer 8504 126 15011 works intermittantly
why do you need a freezer if you only have ice
Nov 07, 2009 | Washing Machines
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
Bottom of feezer building up ice and leaking
This just happened to me. take the panel off inside of freezer and you will see the evaporator fan this could be the problem. test it before placing.Also there is a thermostat in there too. A little round device that will kick the fan on when the temp is around 34. Both parts together are about 90 bucks if you get them yourself online. About 170. through a dealer.
Apr 10, 2009 | Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
168 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
