Question about Apple iPhone Smartphone
Iphone 3G wont turn on.
I was just sitting at my desk when i put my iphone down for a second and the screen went black (like it usually does when i set it down for 5 seconds) and when i tried to turn the home screen back on, it wouldn't turn back on so i put it on the charger and it made the little noise but the screen wouldn't light up. please help! thank you.
I forgot to charge iphone 3g battery and all of the battery went down, later i try to charge it and put it on charge the whole night and try to turn it on by pressing both wake/sleep button and home button...
try to connect it to your pc with your speakers on, if it's not completely dead the pc will give a beep that it's connected.If that happens everything will be fine.
tell me what happens.
Apr 19, 2011 | Apple iPhone Smartphone
My Apple IPhone 3G Screen just went blank. It sync's to my ITunes and I restored it but in never turned back on. Any suggestions?
Sorry to read about your problem, I hope this helps you out.
you will have to put the phone in the DFU mode and restore with itunes
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Apple iPhone 3G
I think the display screen on my iphone 3g went out. how do i check?
Reset the phone:
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 12, 2010 | Apple iPhone 3G
IPhone wont turn off
Unlock the screen.
Press the button on the top of the phone and hold it down.
In approximately 5 seconds a "slide to power off" message should appear.
Slide the slider and power off the phone.
If this does not work take it to an Apple or AT&T store.
If this helps please vote for my solution.
Jun 24, 2010 | Apple iPhone 3G Black Smartphone
Iphone wont turn on!!!
Hi slondon83,
I believe you will have to reflash your device, using the restore feature on iTunes and the CFU mode in you iPhone.
To restore your iPhone, you will have to enter to CFU mode:
1. turn off your phone, or wait it get turned off by itself.
2. press and hold the power button for exactly 3 seconds.
3. whithout leaving the power button, press the HOME button for another 10 seconds exactly.
4. after 10 seconds leave the power button but still, keep the HOME button pressed.
try all these steps, of course, while you iPhone is connected to your computer with the USB cable and the iTunes software is on.
you might be able to do it with this method too:
good luck!
Aug 29, 2009 | Apple iPhone 3G
Iphone 3g screen wont come on i can hear the
You may need to try a restore. If you plug in the phone and itunes sees it try to do a restore. If it won't with the phone off hold the power and home button for 6 secs. then let go of the power button but not the home. Hold until itunes sees it and you can restore.
Aug 18, 2009 | Apple iPhone 3G Black Smartphone
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
My iphone wont respond to my touch in the bottem halk
Have you tried doing a hard shut down? Hold the silver button down on the upper right corner and also the home button (center,bottom indented button) together for about 10 seconds. the phone will completly shut off. then wait about 10 seconds and hold down the upper right hand button until the apple appears on the phone then release the button and wait (20-30seconds) . Doing this usually solves all my issues with my iphone when it gets locked up like this.
Jul 01, 2009 | Apple iPhone 3G Black Smartphone
My Iphone wont turn on
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Mar 24, 2009 | Apple iPhone 3G
Iphone 3g ,
Hold down the power button and home button for 10-60 seconds. Your iPhone will shut down and when the screen is black plug it into your computer like you want to charge. The screen will load good as new(or atleast mine and a few others have.
Jan 06, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
153 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
