Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
My 2wire USB adaptor will not uninstall
I have this same exact problem as this person below:
"When the screen came up that asked for my SN and key I used the same ones that had worked before. It told me that it couldn't connect, possibly due to a bad key. I retyped it several times till it took me straight to the 2wire wireless manager which said that it could not detect the card. I tried uninstalling and reinstalling it with no success. There is also a program in add/remove programs called "2Wire Wireless LAN USB Driver" that tries to get me to reinstall the manager when I click "remove", that I cannot seem to get rid of. I've searched on the internet and found people with the same problem but no solutions. When I try using the hardware wizard on windows XP, it just says that it cannot find the right software. Plus, whenever I uninstall (then reboot) then try to reinstall, the menu from the 2wire CD asks me if I'm sure I want to UNINSTALL the wireless manager before taking me to the install screen."
  • 24 Answers
SOURCE: 2wire wireless adapter
Try using the Ethernet (network) cable instead of the USB connection.
Hope this helps!
Posted on Jan 31, 2008
SOURCE: 2wire wireless adaptors
I have installed 2 2wire adapters with no problem. When using config software utility, don't select gateway (if using only adapter), then continue until sets up. No serial # required unless using a gateway, which is not needed to connect to wireless.
Posted on Mar 01, 2008
  • 13 Answers
SOURCE: i need to setup the 2wire adaptor for my computer but lost CD
Google the term "ZD11BUXP" to dwonload this windows update and it shall resolve your problem
Posted on Jan 19, 2009
  • 57 Answers
SOURCE: have a 2wire wireless adaptor, the software cd was
You can download the drivers from the link below:
http://support.2wire.com/index.php?page=download
You can either save it or just open the file to run it on your computer.
Posted on Jun 30, 2009
Ezrahite
  • 2632 Answers
SOURCE: Computer can't detect 2wire adapter
*Heres the thing youre doing the right thing install the driver, make sure that you remove the the 2wire wireless manager in the add/remove program and leave the 2Wire Wireless LAN USB driver
*To connect your computer to the 2WIRE router make sure you know your SSID or the network name and the network key, if you call the AT&T Uverse tech support they will ask you to configure the wireles network key to your phone number
*The default SSID is 2wire and the last 3 digits of the serial number of your Router and the Default Netowrk key is located @ the bottom of the router theres a sticker and it is under S/N
Posted on Jul 21, 2010
How do I add a password?
the password for 2wire if you got it from your ISP is most likely on the bottum of the unit on a sticker
Jul 28, 2010 | 2wire (1000-400108-001) Router
Installiong 2wire usb wirelees adapter. Now configuring-wont let me type in serial number. now I'm stuck
I had to reinstall my 802.11b legacy 2wireless adapter. installation went fine until I had to enter the sn and wireless encryption key off of unit. These numbers are on wireless unit but have letters. The software won't accept what is written on unit. What do I do?
Feb 21, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Connecting Netgear USB adaptor to 2wire modem
Install the Adapter using the CD, After installing if its windows XP it will ask you to choose XP utility or Netgear utility, choose windows and scan for the network.
If its windows vista , go to start-Connect to - u will see the network name here , try connecting to it
Nov 14, 2009 | 2wire HomePortal® 1800HW Router...
Need help connecting a 2wire usb adaptor without the software
You need the drivers. An oversimlified analogy of what a driver is - drivers are what the computer uses to translate the language the devices speaks into a language the computer can understand. It allows the two to talk to each other.
You should be able to download the drivers for this device at http://support.2wire.com/index.php?page=download
The manufacturer for any device that you connect to your computer should have the drivers necessary to install it on their website. If the device you are trying to install is a network device (wireless or wired) and you are unable to access the internet, the best suggestion I have is to borrow a friends computer and a USB key/drive or have them burn a CD with the drivers on it for you.
Aug 09, 2009 | 2wire Computers & Internet
Was given a 2wire modem without the setup CD. Can I use it?
access the modem interface
by typing at the address bar 1920168.1.254
click on broadband link
then bellow that advanced settings
should ask you for a password
clik on forgot password and then still cant remember password
then it will ask you for system key its on the modem and should be 10 digits long in bracketts
on a sticker by the SN no.
type that should take you back to the main page again
broadband link - advanced settings
you should have a primary email address from your ISP
type it in where it says username then the password where it says password
then confirm
then save you should be on the web
Apr 10, 2009 | 2wire 2700HG-B Router (2700HGB)
I would like to get my wireless modem light on....how do I do that (how do I get my wireless modem to go wireless).
Go into 192.168.1.254, then go to "Home network", then "Wireless settings" put your network name in the blank box.
Mar 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Can i download the software for setting up my modem?
The only time you really need software to set up the 2wire is if you are going to the use the USB ports on the back of the 2wire. The 1000 series have wireless capabilities. Since you have a new laptop, it should have wireless capabilities.By default your network name should be 2wireXXX and the XXX is the last three of your SN. The network key for the 2wire is the 10 digit number that is in brackets
Hope this helps you
Oct 23, 2008 | 2wire 1800HG Router (RG1800HG00)
Jul 25, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
421 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
