Question about Sansui 27" TV
How to add new digital channels on Sansui digital TV
I have an external antenna on a rotor to pick up DTV from 2 different cities. My Sansui HDLCD2600 does not appear to allow a channel scan to add new channels to memory; ie, when you do a scan to add the channels for the second city it wipes out the channels scanned from the first. Does anyone know how to add new digital channels on the Sansui line of digital TV's?
likha
  • 790 Answers
SOURCE: 13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Posted on Oct 12, 2007
ltfrc
  • 227 Answers
SOURCE: is my sansui sdtv 3200A dtv ready?
SDTV The "D" means 'Defenition' not Digital, S is for 480i. You will need a convertor box. Sorry.....
Posted on Feb 16, 2009
SOURCE: Can't get one local channel when hooked up to T.V. antenna
Take a gun and shoot your self.
Posted on Feb 19, 2009
memturbo
  • 226 Answers
SOURCE: trouble getting digital on a sansui 27"
your antenna is not strong enough to receive
digital or your in a area where large
structures are blocking the reception.
you could try turning the antenna slightly
and rescanning .
Posted on Jun 12, 2009
  • 83 Answers
SOURCE: how do i add channels on my sansui television
check your cabel canaction is not proper or bad singnel
if ok than
Auto chennal serch to fix your all ch. ok?
if not then
problum is in side of tv . tunig voltage is not proper 33v so pls check with nr tech. fix this problum essly.
Posted on Oct 30, 2009
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
DTV1300A Sansui is not dtv ready, Am I doing something wrong?
To put your digital channels into the memory of the DTV1300 or 1900 press the MENU/ENTER button. Go to CH SETUP. Press the VOL + button. Go to TV CABLE. Use VOL+ button to set to TV for antenna or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL+ button. Wait for the search screen to go away after the analog and digital searches finish on their own. Check ALL your channels with the CH up button. I hope this helps you.
Mar 14, 2009 | Sansui DTV1300 TV
Is my sansui sdtv 3200A dtv ready?
Feb 16, 2009 | Sansui DTV3200 32" TV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Dtv box
the box broadcasts through channel 3 thus you have to set your tv to channel 3 to pick up the signal. There is a menu to use once you get a singal to pick up the channels. You may also want to call the 1800 number on the back of the remote, they will wallk you through the problem.
Jun 16, 2008 | Insignia Digital-to-Analog Converter for...
Sansui 27" TV Logo
438 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
