Question about Epson Stylus Pro 9600 InkJet Printer
Epson 9600 no ink coming out
Hi, I had some problems with the 9600. to my opinion it didn't print enough yellow ink. I have changed all the dampers - and indeed yellow damper was blocked. After putting everythinh back together printer doesn't print any ink - print heads moves like it is printing, but no ink comes out at all. Would you think it maybe the head? someone suggested that maybe cables?
Appreciate any advice.
That happens to me as well I'm using epson R230x pigment ink. At first yellow does'nt come out. and fixing the yellow by pumping it with a solution and putting everything back ALL HEADS ARE NOT PRINTING ANYMORE....
Posted on Jan 15, 2010
Ink streaks on print epson 9600
The problem solved by "switching off" the Digital Signature.
Since the driver from Epson was safe it was allright and safe to do that...
Apr 02, 2013 | Epson Stylus Pro 9600 InkJet Printer
Stylus Pro 9600. LC damper has a leak and the printhead is clogged. Is there a video or photo spread on how to replace both? The ink line at the damper looses vacume/prime. Thanks...
There is a website www.americaninkjetsystems.com that has pictures posted on how to take apart the Epson 9600 printer and get to the Dampers and Printheads.
Jul 03, 2011 | Epson Stylus Pro 9600 InkJet Printer
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
Printers do not recognize yellow cartridges
http://www.fixya.com/support/r3845491-ink_cartridge
Check out there FIRST befoe you get into things too deeply
A lot of common tips that tend to help a lot of people.
Bob
Jul 22, 2010 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Apr 23, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 Magenta problems...
sounds like a problem with the damper/cleaning unit.
You need to clean the "pads" under where the print head parks.
Turn off power. open front cover. push it cutter (blue) and slide printhead to the left.
You will see a pad in there. this is the cleaning area. Remove and clean. Also next to this is a wiper. it is vertical and needs to be washed with some rubbing alcohol.
try these and get back to me.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson stylus pro 4800 black ink problem
When you put the printhead back into the machine, did you seat the dampers correctly?
Aug 07, 2008 | Epson Stylus Pro 4800 InkJet Printer
Unclog yellow
Same problem yellow almost completely clogged, any tried a power clean from the printer control panel?
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
569 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
