When ever I want to start NeroStartSmart software for making CDs I get a prompt that the application can not run as oledlg.dll not found. I have reinstalled the application with same results..
Restore your computer to earlier time when it was working fine and if that doesnt work try the steps below.
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
if the above doesnt work try below steps.
please use msconfig as directed below and stop unwanted programmes to run in baground.
This will also improve the performance of your computer.
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
4. Click to clear the Load Startup Items check box.
Click apply and then click close.
8. When you are prompted, click Restart to restart the computer.
after restaring you will see a box stating you have used system configuration utility. Give a check in the box (do not show this message again and click ok.
If you click on this link you can download it http://www.dll-files.com/dllindex/dll-files.shtml?oledlg
