Question about Cameras
I pulled out an old Elph 2 Canon camera and can't remember how to open the memory card compartment.
RadarRon
  • 398 Answers
SOURCE: Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Posted on Feb 12, 2008
t00nz
  • 4738 Answers
SOURCE: Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
Posted on Jun 07, 2009
hsanfor
  • 71 Answers
SOURCE: memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Posted on Jun 17, 2009
leecom72
  • 4806 Answers
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Posted on Sep 03, 2009
  • 186 Answers
SOURCE: Can I use a 4GB SDHC memory card in my Canon Power
If not you'll most likely get a "card error" message.Check with manufacturer for compatible memory.
Posted on Sep 22, 2009
How should I do to open card locked Canon IXUS 65
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 19, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Powershot sd630 digital elph busy can not reset and says busy when deleting one picture
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cant format new 4 mb memory card on PowerShot sd700 is digital elph
If you cannot format the memory card using the format function of the camera, please connect the camera to your computer and use the computer to access your memory card and format fromt the computer.
Alternatively you can also use a memory card reader and connect the memory card to your reader and connect it inturn to your computer and format it from the computer
Dec 25, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
I cannot find where the memory card or film goes in this camera.
Your camera takes APS film. It's an obsolete system these days but the film and processing are still fairly easy to get.
The film loads into a compartment on the bottom of the camera; you open the compartment by turning the latch on the right hand end of the camera (as viewed from behind). The battery fits into a small compartment on the lower left back of the camera.
Click here to download a manual for your camera.
Enjoy your camera, and please take a moment to rate my answer.
May 11, 2010 | Canon Elph LT 260 APS Point and Shoot...
Slow shutter speed
1. Low battery 2. Memory card has too many pictures on it. 3. Memory card needs to be formatted in the camera after downloading the pictures.
Dec 13, 2009 | Canon PowerShot SD880 IS / Digital IXUS...
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cant transfer pictures
TURN CAMERA ON FIRST, PLUG IN USB, GO TO MY COMPUTER, YOU WILL SEE A DRIVE THAT HAS YOUR CAMERA ON IT. YOU SHOULD BE ABLE TO DOUBLE CLICK AND OPEN THAT DRIVE.
ANOTHER THING YOU CAN DO IS TAKE MEMORY CARD OUT OF CAMERA, PUT MEM CARD IN COMPUTER, GO TO MY COMPUTER, FIND DRIVE WITH MEMORY CARD. DOUBLE CLICK AND OPEN FILE.
YOU CAN CLICK AND DRAG PHOTOS FROM THAT DRIVE AND DROP THEM IN ANY FOLDER OF YOUR CHOICE.
YOU MUST HAVE THE LATEST USB DRIVERS FOR YOUR EXACT CAMERA FOR YOUR COMPUTER TO READ IT.
Mar 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannot load picturesw into the computer
hi there!
.in ur power shot search for a small compartment that holds a tiny rectangular shaped MEMORY CARD.
.remove the card and stick it into a card reader(a narrow slot) that is connected to your computer.
.next goto Start -> Accessories -> Scanner and Camera Wizard
.Choose pictures and move all the pictures into one folder on your computer.
Dec 05, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera dropped in snow
Where on earth do you find snow this time of year ? If moisture has got inside the camera, chances are it's ruined, I'm afraid.
May 22, 2017 | Canon PowerShot SD400 / IXUS 50 Digital...
Memory Card
b32f20a.jpgPowerShot SD630
Camera will not power on with a memory card installed.
1. Try another memory card and contact the memory card manufacturer 2. The PowerShot SD630 requires repair service.
This information sourced from Canon Support Forum page here
Jun 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
