Question about HP vs15 15"LCD Flat Panel Monitor
Problem on hp monitor
Hi,i have a hp pavilion f1523 monitor,the problem is that the main menu display and osd lockout keeps appearing on the the srceen for no reason,I've had the monitor for five years & never had this problem until the last 2 weeks.I've tried all the different options in the menu sections.this problem is very annoying.Can anyone give me any advice to resolve it?
I have the same problem. OSD lockout, OSD locked, auto adjustment in progress and the menu screen are always popping up my touching anything. I've tried holding the menu button for 10 seconds, but it doesn't work. Is there a solution to this annoying problem?
  • 2 more comments
  • Renee Nelson Jan 14, 2008
    HP f2105, 21" screen is doing the same thing . How do you unlock OSD Lock out and have my display in Menu back, choice in the Menu botton when held for 10 seconds ?OSD Lock out to stay off from blinking off and on or have the the OSD Lock out to stay off completely! Had this problem July some time ..
    I have a HP f2105,21" screen monitor also have this problems! How do you get the OSD Lock out completely 2"x5" square white with OSD Lock out printed in black off the center of my PC? and have my menu display back with choice in menu box 5"x 8" with Choices inside this display back? Do I have to take everything out and reinsteal again from my disk I got with my computer? start all over??? Please help me resolve.7 months putting up with this. (TO LONG) annoying and can't work on Computer- Play my games. HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! RN_51. 1/13/2008-posted.
  • compguy1 Jun 27, 2008
    Same problem on my HP f2105. Flashing OSD lock out and menu screen with frozen buttons.
  • Anonymous Mar 15, 2014
    How do I use the buttons on the front of the monitor to reach the "R ->" display?
    Problem Solver:
  • 9 Answers
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
Im experiencing the same ISSUE!! I will NEVER buy another HP monitor again!
Posted on Feb 29, 2008
3 Suggested Answers
SOURCE: problem on hp monitor
To lock the OSD, press and hold the Menu button while the monitor is off, and then press the Power button to turn the monitor on.
To unlock the OSD, repeat the locking procedure.
This took me several tries before it worked. So keep trying.
Posted on Jan 27, 2008
viziks
  • 220 Answers
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir.
Posted on Apr 08, 2008
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
Osd lockout
press menu then start the power
Mar 20, 2010 | HP Pavilion F1523 15" LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
How the unlock osd
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
Hp w2007 lcd monitor, osd lockout & main menu display
Once you realize that resetting it doesn't work (as I did ) take it apart. This instruction is for an hp w2007 only! It's the one I just fixed. Remove the three screws holding the base on. The one in the middle is hard to see because it's in a hole but readily accessible. Remove the black back cover by inserting a skinny screwdriver between it and the gray housing. Start in the middle on any of the four corners.Pry it up and work your way to the corners. At the corners pry up with more force and the plastic tabs will snap off. Trust me, just do it!! Once you have snapped the plastic tab at all four corners the back will lift right off. locate the three small wires that go into the menu, -, +, select switches. Cut the three wires and tape them off separately. Do this so they can't touch the case or each other. Do to the wires that are going back toward the monitor! The ones going to the switch do not need to be taped. The switches are now dead. Is that clear? Cut the wires going to the switch and tape the cut ends that go back to the monitor. You will no longer be able to manually adjust anything but I never used the adjustments anyhow. The PC will take care of it for you. I did this 8 hours ago and it's still working perfect! Before I made the fix I was getting OSD Lockout, no input signal, it was scrolling through the menu and the screen was going blank every 5 minutes!! It will work!!!
Oct 11, 2009 | HP Pavilion F1523 15" LCD Monitor
Osd menu keeps popping up
It is the malfunction of the monitor button or circuit pannel responsible for OSD. Get it repaired/replaced.
Regards,
Shrey
Oct 02, 2009 | HP Pavilion F1523 15" LCD Monitor
Samir.
Apr 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP vs15 15"LCD Flat Panel Monitor Logo
740 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
