Question about HP OfficeJet d145 InkJet Printer
Not coping When I press copy it starts to copy the document but half way throgh, it just stops
How do I copy from document feeder?
Dear Flaim
pl. do load documents on the adf tray.face upward and the press copy or start. it will do
thanks.
Apr 02, 2015 | HP Officejet 5740 Wireless e-All-in-One...
Memory full
Deleting a Document from Memory
1 Press [Menu].
2 Use UP or DOWN arrow to select MEMORY REFERENCE, then press Start/Copy.
3 Use UP or DOWN arrow to select DELETE DOCUMENT, then press Start/Copy.
4 Use UP or DOWN arrow to select the transaction number TX/RX NO. of the document you want to delete, then press Start/Copy. The LCD displays YES=(*) NO=(#).
If the LCD does not change after you press UP or DOWN arrow, this means only one transaction is stored in memory.
If you are unsure of the transaction number TX/RX NO., print a list of documents in memory (see page 34).
5 Press [*] to delete the document.
If you want to keep the document in memory, press [#].
6 To continue deleting other documents in memory, repeat the procedure from step 4.
To finish, press Stop.
Feb 28, 2012 | Canon FAX-JX200
How scan from this fax?
1 Load the document in the ADF.
2 Press [COPY].
3 Use the numeric buttons to enter the number of copies. (up to 99)
4 Adjust any necessary settings for your document.
5 Press [Start].
NOTE
To cancel copying, press [Stop/Reset].
Dec 09, 2011 | Canon FAX-L380 Plain Paper Laser
Whenever I am coping with paper 8.5 x 14 it does not copy the bottom part of the document.
You have to set the scan option to 8.5 X 14 original paper before you copy to copy the whole paper, otherwise it assumes 8.5 X 11, and stops scanning at the 11" mark.
Use the copy option button rather than the copy black or copy color buttons.
Without knowing the make and model, that's the best advice I can give, but you should be able to figure it out with this information!
Jul 23, 2011 | Office Equipment & Supplies
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Copier not coping due to teo messages on the display, 020 and C-6
Hello sir; your machine temperatur too high need to reset the procedur as follow;
1, press "stop/clear" key, "start" key", and left copy density key.
2, press "stop/clear" key again.
3, enter U163 press "start".
4, when screen display "CLE" then press "start" again to reset.
May 29, 2009 | Kyocera Office Equipment & Supplies
Copier not coping documents placed on the copier. In addition, when coping from the computer it only copies part of the document.
If you are able to print form the computer.
Then follow the following steps:
Take out both the cartridges from the printer and unplug the power cable from the All-In-One and the wall outlet.
Leave the power cord unplugged for at least 1Mins time.
Connect the power cable directly to a wall outlet without a surg protector.
And before connecting the power cable back to the All-In-One press and hold the # and No 6 button and connect the power cord do not release the keys untill you see a message as Semiful reset.
And if the unit is turned Off then release the keys and turn the power on and try copying or printing.
Good Luck
Aug 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
HP OfficeJet d145 InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
