Question about Maytag Refrigerators
How to stop water from pooling on the middle of shelves. The water seems to come from nowhere. Also, what is the best setting for the humidity sliders on the fruit and vegetable drawers.
  • 40 Answers
If it is a static appliance with a ventilator this can happen at colder settings you can try to increase the setting so the condensation can be decreased.That water is the condesed water which comes from your food.
Actually these has a very small impact if you do not have %100 sealed drawer.If you have fresh vegies it should be totatlly closed so the humidty levels increase in the drawer so the freshness.
Posted on Sep 27, 2009
Stopped humidifying, water remains in the container. everything else seems to operate fine
If you are using the misting type humidifier rather than the wick-type. there could be a blockage in the misting aperture. These units clog easily, and it is best to use distilled water in them since mineral deposits can clog the aperture.
Feb 15, 2016 | Humidifiers
How can I stop condesation building up on back wall of freezer side ? Water is running onto floor and pooling up.
Good Morning Friend,
I understand you have condensation building up on the back wall of the freezer side of your Frigidaire refrigerator, model# FGHC2342LF. I also see that this is a new refrigerator for you, and the water is pooling on the floor. It would take 24 hours for your refrigerator to stabilize at the set temperatures. First, I suggest giving it this timeframe. Secondly, if it is hot and humid, this is normal and can occur. Lastly, check with your installer to make sure that your refrigerator was installed correctly. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FGHC2342LF Side By Side...
Water leaking on freezer shelves no water in ice maker
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
Where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
Water keeps pooling up on the bottom of my fridge and freezing
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Jun 03, 2012 | General Refrigerators
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Water dripping from under feezer, have ice maker, shelves get soak and wet. model 71182100
Check to see if your refer has a climate controll ie: humidity setting, some models of refers swet when the humidity is high, if it doesn't have this setting turn your freezer setting down alittle. GL hope this helps.
Jun 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge has water pooling on the shelves and under the drawers.
check the door is sealing properly, use a note book page and close the door on it , then see if you have got some resistance when you pull it out. Do this on all `sides `. Is the drain blocked ? Are all high moisture content foods covered. Are you in a tropical area ? This can also make a differance.
regards ****
Apr 01, 2009 | Kenmore Refrigerators
Refrigerators Logo
118 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
