Question about Microsoft Windows Vista Ultimate Edition
Vista basic How do you clear or empty the D- drive.
  • boonstein Dec 19, 2007
    That was the fix, when you format the drive it delets what is on the drive. Thank You
  • 41 Answers
If you have 2 drives local c and d click on my compuer and you will see local c and d right click the d then scroll down to format try that
Posted on Dec 17, 2007
What's he drive train cycle for 2003 audi a6
Throttle Body Alignment (TBA) - Ross-Tech Wiki
wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)
This procedure cycles the motorized throttle body through various states (idle, part ... The TBA can be performed on both Drive-By-Wire (DBW or E-gas) as well as ... Typically, '96-'99 VW/Audi have motorized Cable-throttle, and '00+ VW/Audi ... 5 and 95C; If fault codes were cleared cycle the ignition off and back on prior to ...Missing: press ‎train ‎clear
How to Perform a Basic Drive Cycle - RepairPal
repairpal.com > Car Care Advice > How To's
The Drive Cycle is one of the methods used by the powertrain control module ... ADrive Cycle is a special test drive that duplicates the scenario of a person ... This signals that an emission system problem and fault code has been ... If the fuel tank is near empty or completely full, many of the basic tests will not run at all.
Anyone have a drive cycle on how to drive the car after fixing one
Dec 02, 2015 | Audi Cars & Trucks
How to install
As long as the hard disc you intend to put it on is empty then placing the disc in the drive of your computer should be all that's needed to start it.
May 26, 2013 | Microsoft Windows Vista Home Basic for PC
I have a HP2133 which runs Vista Home Basic. I want to do a reinstall from the HP Recovery (D) but this appears to be empty and when I restart and use F11 I get the response that BOOTMGR is missing. Any...
This is not a Hardware problem It is purely problem of your Operating System Vista Home Basic.
  1. In order to solve this problem enter your PC's setup by pressing "F2" again and again. Some PCs accept "Del" key instead of "F2". You will enter the BIOS Setup. Give your CD/DVD highest priority to boot.
  2. Insert your Vista Home Basic disk in the CD/DVD drive and let it boot.
  3. The computer will ask you some simple information like keyboard layout currency and Language after this you will You will be asked to "Repair" or "Install" Windows Vista.
  4. Vista System Recovery tool will start.
  5. Select Startup repair.
  6. Your Vista will take care of the rest.
If this does not work follow the previous steps from 1 to 4
  1. Select "Command Prompt" instead of "Startup repair"
  2. Type in the Black command prompt Window bootrec/ rebuildbcd and press enter.
  3. You will be asked to enter an entry in the BCD store from Windows Installation path directory. Select "Yes".
Your problem will be solved.
Good Luck!
Dec 12, 2010 | Computers & Internet
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
Cd drive shows in my computer but does not read
make you pc empty and restore every thing trow every thing away you software and hardware than new software on
Dec 31, 2009 | Microsoft Windows? Vista Home Basic...
How to install Visual Basic .Net Standard 2003 ona Vista
hi, Well sorry to tell you that one can not install .net 2003 on window vista as it is not supported by vista. You can verify this information on microsoft website and it is clearly mentioned there that it is not supported so you can not install it on vista.
regards, poly
Oct 16, 2009 | Microsoft Visual Basic .NET Standard 2003...
Install xp on vista home basic toshiba satellite L-40
Yes, Vista Home Basic is junk!
1.Vista is considered an upgrade, compared to Windows XP. Therefore, Vista is not just going to let you install over it.
2.You have to get your Windows XP drivers back.
This is a pretty intricate operation, but once you have detailed information, it becomes do-able.
Below is a link with detailed information, and concise clear illustrations. I felt it would be better to give you this link, to avoid any confusion, and/or misunderstanding of information from me.
Should get you on your way!
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
May 16, 2009 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Upgrading from millennium to Windows Vista on my hp palivion laptop. What can i do?
First you need to go to microsoft.com and run the vista compatibility tool to make sure the computer will take vista.If it will,You will need to download all the vista drivers for the hardware you have now .
Then,just install
More details available if needed.
May 14, 2009 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
