Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Inserted new black cartridge but printer unable to see it. Printer says No cartridge.
  • 49 Answers
SOURCE: replacing cartridge
Try turning off printer at power point, leave 5 to 10 minutes and turn on again, if still not regognised, try new cartridge and if that works, take the one that didn't work back for exchange.
Posted on Jul 03, 2008
joshblaine
  • 65 Answers
SOURCE: have inserted new black ink
Some printers are proprietary, meaning any cartridge won't work even if they look the same they have to be purchased from the manufacturer of the printer.
Posted on Sep 16, 2008
the kowalski
  • 86 Answers
SOURCE: brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Posted on Jun 03, 2009
micromatikal
  • 2777 Answers
SOURCE: "No Black Ink Cartridge" after a new cartridge has been inserted
It sounds like the actual ink sensor has failed. You can check if it has a print head cleaning routine in the software on the computer. Most likely the actual ink sensor has died though, I've seen this many times. Call Brother to confirm, or maybe if it's still under any kind of warranty: 877-276-8437
Posted on Aug 08, 2009
aviral_srms
  • 1216 Answers
SOURCE: Printer will not print. It
Please take a note that you can only refill the ink 3 times before the print head dies.If this is your first refill then you probably may have air in the cartridge.
take a look here if it helps
Posted on Jun 28, 2011
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I changed the black and color ink cartridges on my Lexmark 2500 printer but both of the ink lights continue to blink off and on. I'm unable to get the printer to reset by disconnecting the printer and...
Make sure you are inserting the correct versions of cartridges for your model. Try to re-seat the cartridges by removing and re-inserting the cartridges in the carrier. The black cartridge goes in the left carrier while the color goes in the right. Also, make sure you are using genuine Lexmark cartridges.
Jun 27, 2011 | Lexmark X2500 All-In-One Printer
I am unable to insert the Ink Cartridges in HP 1315 Printer
Hi
Make sure you've got either 56 or 27 black and 57 or 28 colour cartridges. See here:
http://www.inksave.co.uk/product/PSC-1315/
You "pop" them down then withdraw the old ones. Put the new ones in angled slightly upwards then click them up into place. The raised plastic on top of the cartridges will prevent installation into the wrong ports. If you're trying to put in a 58 photo cartridge it goes into the black port.
Good Luck!
Feb 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Brpther DCP 330c does not recognise new black ink cartridge
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Have installed new epson black ink cartridge in c1100 printer. unable to press down locking bar on this new cartridge
Try re-inserting it again, L/H side should go in slightly ahead of the R/H. Give it a push & wiggle and it should lock in. An alternative method of fitting the cartridge is to open the top cover & remove the PCU. With the front cover shut you can rotate the cartridge "carousel" until the black is in the 2 O'clock poition when looking from the R/H side of the printer. You can now insert and lock the cartridge into place.
Please take a moment to rate this solution, thanks.
Apr 11, 2009 | Epson Aculaser C1100 Printer
Printer will not recongnise new black cartridge inserted
yes, the printer is having a hardware failure. reseating the cartridge is the only troubleshooting you can do.
Dec 09, 2008 | Epson Stylus Photo R220 InkJet Printer
Unable to insert ink cartriges
just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the black cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur side.fit the new cartridge in the reverse procedure.
follow the same for colour cartridge.
thanks.
Sep 16, 2008 | Office Equipment & Supplies
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
132 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
