Question about Yamaha YSP-900
YSP900 won't turn on. It used too turn on after unplugging the unit from the mains for a while but now it won;t turn on at all. Tried the fuse and fitted a new one (5 Amp). Help!
Panasonic plasma TV blinks seven times and won't turn on
You can't determine whether a capacitor or fuse is OK by looking at it. The Panasonic "tech" has to have known that the cure was not simply a reset. I believe you have a power supply problem that needs attention
Apr 01, 2013 | Panasonic TC P55GT30
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Unit comes on but seems to be stuck on drain cycle. Have had unplugged for day and tried to start a load and still sounds like its trying to drain, door won't lock, and unit won't shut off...
Good evening
Have you had a look at the manual?
Could a fuse in the machinery have blown?
seems to me that here is something to do with the electronics that is not functioning as it should.
Kolbrun
Feb 26, 2012 | Whirlpool Washing Machines
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
The TV won't turn on. No power at the unit. Tried different outlets with no change
ensure that there is power in the mains, then if power is present then unplug the cable and check the cable plug if the fuse is burnt and replace. if this still does not solve your problem then you can open the tv cover carefully and be cautious as the tv may have not discharged fully. check the ``power in`` fuse and measure its continuity, measure the rectifying diodes and ensure all are healthy also check the power ic which should be STR series for that matter. by doing this your problem will have been solved
Sep 21, 2011 | LG 47LH50 47 in. HDTV LCD
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Tevion LCD4203ID, turned televsion on by mains plug, no power being received by television. Have tried different mains adaptor so is definately television. There is no red light or green light on...
Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Sep 04, 2011 | Televison & Video
1998 Toyota Sienna. Problem: Passenger side windows won?t go up. I have replaced window motor but still won?t work. I don?t hear the new motor running when I use two (driver and passenger) switches. I...
Have you tried replacing the master window switch? Just because the other windows work doesnt mean that switch for that window is good.
The main switch is controled by the drivers door main unit.....i had to use a forward force on my windows switch for it to work....so replaced the whole unit, you could find those on ebay cheap if local auto parts is expensive
Nov 06, 2010 | 1998 Toyota Sienna
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Yamaha YSP-900 Logo
51 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
