Question about Jenn-Air Refrigerators
Will not deefrost-the heater has cont - Jenn-Air Refrigerators
  • 358 Answers
Maybe there's a problem with the defrost timer or the defrost thermostat.When the coil is all cover with ice , check if there's continuity through the defrost terminator (little round metal thing attached to the coil), if yes ,the timer is bad.
Posted on Sep 27, 2009
Where is blower fan fuse what numbers
Blower fan fuse is typically shown as heater fuse on the fuse panel either inside car fuse panel or the panel under the hood. If after replacing fuse it still not working. Then the heater motor may need replaced.
Nov 10, 2015 | Jeep 02 03 04 05 06 07 Liberty Audio...
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
When air cont is on it blows heat
It might be the vacuum motor on the blender door letting air pass thru the heater core instead of sending it thru the evaporator.
A simple vacuum line falling off or breaking at the heater can cause this,OR a bad vacuum motor.
don-ohio
Sep 14, 2011 | 1994 Dodge Intrepid
Correct eec for 1989 ford f150 5.8l
Here is a listing of all possible computer modules for that truck. Perhaps this will help in some way in your search.
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), High Altitude
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z2B
Dec 15, 2009 | Ford F-150 Cars & Trucks
Coil freeze up
If the fan works , probably the unit is low on refrigerant, which means there is a leak that has to be fixed and then recharge the unit .Also could be the defrost system (heaters ,terminator or deefrost timer ).
Oct 02, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Why is there water in my crisper drawer?
Hi, The deefrost drain hole inside the freezer is plugged. Remove the rear panel inside the freezer and remove the ice plugging the drain. Make sure to flush the drain hole with hot water making sure it drains.
Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Freezer will not auto defrost , coils icebound
The problem is in the defrost timer , heaters or the defrost terminator ,most of the cases is in the timer you can turn it until the compresor off and if the coil is frozen the heaters will came on if this happend the timer is bad but if the freezer coil is frozen and after you turn the timer to the point that the compresor goes off and the heaters won't kick on it means that the heaters are bad or the defrost terminator fail .YOU can check the heaters for continuity and replace the one thats open or you can buy the deefrost kit which came with the heaters and the deefrost terminator.
Apr 18, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Gss25jfmc side by side
Either the defrost heater (in the coil) dont work or the deefrost termostat(round thing with two wires atached to the coil) or the timer (black thing with a plug with 4 o 5 wires),it could be at the botoom front of the refrigerator,pulling the grill,or inside the fridge in thecold control box.
Mar 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Switch on heater is not working
it pops out forward. put a slim blade screwdriver or knife behind the edge and prise it forward
Oct 18, 2008 | 1999 Mazda 626
Refrigerators Logo
89 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
