Question about Canon PIXMA MP190 All-In-One InkJet Printer
Printer works fine,copier worksfine,but everytime i try to scan i get an error message 2, 155, 0
5 Suggested Answers
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Posted on Oct 21, 2009
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Posted on Dec 22, 2011
I cannot scan through the network to my computer which has windows 7 with Panasonic KX-MC6020 copier. Everytime I go to scan it says communication error or device not found. I have try to scan from windows...
Hi!
Make sure your firewall is off and that the anti virus does not block the incoming scans!!You also need to set the privacy settings if scanning smb and make sure the folder is shared!!
Good Luck!
Jan 29, 2011 | Panasonic KX-MC6020 All-In-One Laser...
My HP C5180 all-in-one printer/scanner used to
try to off and on the hp photosmart let scan if not work re-install driver. let me know if still not work for further trouble shooting.
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
My printer and copier works fine, but when I try to scan I get the message, "usb or wireless not connected'
The error message usually occurs when there is a problem with the cable connection between the computer and the printer/copier. The scanning requires a very clean signal between the two units. The cable should be no longer than 2m. Try a good quality cable and the problem should be solved.
Let me know if this works. Thanks.
Jan 27, 2010 | HP PhotoSmart C4385 All-in-One Printer
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
NO Scan Options
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is
the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel
menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Feb 18, 2009 | HP Officejet 7210 All-In-One InkJet...
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger alfredo_torreliza2000@yahoo.com plz send your answer to this yahoo messenger
Jul 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
old marine
old marine
