Question about Car Audio & Video
What a i supposed to charge the capacitor with?
What a i supposed to charge the capacitor with prior to installation, the manual is very vague?
  • 436 Answers
Yes you should. hook everything up and before you put the fuse into the amp circuit by the battery place a light bulb or test light to join the two endstill the light shuts off. once it is off the cap is charged, now install the fuse
Posted on Sep 27, 2009
Is first eye supposed to be off set
from what i can tell, yes and no. if you're using larger line then you can use a non-offset eye. but for smaller line the eye of offset as per the manual instructions which are still pretty vague
May 09, 2016 | Zebco 33 Bite Alert Spincast Reel
How do i charge a 40,000 vdc pyranol capacitor?
via a resistor, and it depends to what voltage? the 40,000 V DC is the max it is supposed to be tested on.
You never us a capacitor just to charge. And you never use it to the max tested voltage.
Feb 06, 2015 | Electronics - Others
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
Where is the 'full instruction manual?'
Depends on model you have, but most mp3 players have built in batteries and hooking them to the computer will charge them, if it came with a software, insert the disk and run the install first. Hook it up and let it charge.
Dec 30, 2009 | Audio Players & Recorders
Tv has power but will not turn on
Very vague but okay let me give you some reasons:
1. bad power supply
2. bad inverter voard
3. bad capacitor inside the power supply
4. burned out fuse.
These are common answers why your TV just is not turning on. You gave me no leway to work with like "my frount power led is red" or "my standby light is bling X times" Vague issues vague answers please od leave postive feedback and ratings for your vague answer today!
Nov 24, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Rockford capacitor question
I think the "chip" is actually a resistor for DISCHARGING the capacitor. If its hooked up right it should charge and the light should go out.
I dont think the "chip" is supposed to hooked to it when it is in use, but check the instructions..
Make sure the wires are right, and try it without the extra device attached to it.
wezmiester
May 25, 2008 | Rockford Fosgate CPCD05-03 Capacitor Car...
Xpress power capacitor
start the car so it will give you 14V
Dec 23, 2007 | Car Audio & Video
Starting Capacitor
Found this Frigidaire question posted under Whirlpool but I'll be happy to answer just the same.
The starting capacitor is connected to the line level voltage, as opposed to the high-voltage capacitor evryone warns about.
The starting cap doesn't store enough of a charge to worry about.
The main thing is to be sure the oven is disconnected from the power line. I prefer unplugging it, but some installations make that hard, so you need to turn off the breaker.
Hood fan failure can happen due to many causes:
If a cooktop light bulb blows or is removed or installed while the oven is still connected to the power line, that can damage the circuit board in the area.
The hood fan motor wiring can short.
The starting capacitor can be bad.
There may be dust, hair, debris, etc. in the bearings of the hood fan motor jamming it. The filters are supposed ot help prevent this, but things happen.
Behind the control panel on Whirlpools is a very helpful mini-manual that can help you check and diagnose quite a few problems with these.
On some brands it's located on the control circuit board, in others it's mounted on or in the hood fan assembly.
If you post your brand and model we can probably steere you better on a mini-manual and the capacitor.
Dec 03, 2007 | Whirlpool MH1150XMQ Microwave Oven
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
