Question about Texas Instruments TI-84 Plus Calculator
Ti 84 not working
My sons ti 84 plus is about two years old. Its kept in the outside pocket of his backpack,so it gets tossed around alot. the problem is no matter what button i press nothing happens. Ive put in new batteries and still nothing.Is there something i can do to fix it or is it just broken. thanks.
  • Texas Instru... Master
  • 7,993 Answers
Since it gets tossed around a lot, it is possible though improbable that the batteries lose contacts with the electrical terminals.
You may try to darken the screen a bit.
1. Press [2nd] key and release it
2. Press [UpArrow] and release it.
3. Repeat steps 1 and 2 in sequence until contrast is satisfactory.
If that does not fix the problem, use a calc-to-calc cable and try sending something to it from a working calculator.
You can also download the TIConnect software from education.ti.com and install it on your computer. Then connect the calculator to the computer by means of a USB cable, a TISilverCable, or a TI Graphlink (Black cable). Turn the calculator ON, run TIConnect, connect calc-to-computer and Click TIDEVICEINFO in TIconnect main window.
If it tells you NOT FOUND, on any of the ports, click the communication settings: Set the device type to you calculator model. Set the cable type. Set the port (COM x) or USB1
If calculator is not detected through any of the available ports (COM ports, or USB), then it would suggest that calculator is in need of repairs.
Hope it helps.
Posted on Sep 27, 2009
Any sin, cos, or tan function problem always gives the incorrect answer. I can use my TI 55 that is 30 years old and get the correct answer, but my son's TI84 plus silver edition is incapable of giving the...
Make sure you have the proper angular mode set. The TI-84 can work with degrees or radians.
Press MODE to bring up the mode screen. Use the arrow keys to highlight either "Radian" or "Degree" on the third line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
If this doesn't do it, please reply to this post giving an example of a calculation and the answer you're getting from the calculator.
Feb 03, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
Does a TI 89 have an advantage over a TI 84 in a 10th grade algebra class? My sons teacher won't let him use an 89. He says it does too much of the work for him. Is this right?
the 89 is in my opinion not need/ approriate for a 10th grade algebra class, or worth the extra money.
for example the 84 wont output variables it must output a number
so your son may be doing factoring, if he inserts (x^2+2x+1) the 89 will allow him to enter it and factor it as (x+1)(x+1) or (x+1)^2 the 84 will not.
the 84 will do pleanty as far as graphing, finding zeros,plotting, calculations, and should get him any answer that he seeks so long that he knows how to use the 84. It just wont give him the intermediate steps the the 89 is able to give.
hope this helps
Apr 05, 2010 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus Silver Edition stopped working
That actually is a result of water damage. You probably need to replace it, or see about getting it taken apart and dried if the water damage was recent. DO NOT take it apart yourself. Go somewhere and ask if that is possible.
Jan 28, 2010 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus calculator without ~ | or y keys
type 15 then click a button that looks like this^. then 365. Then hit enter. it is like a normal clcutor except with more function. Sometimes you need to use the 2nd and the alpha button to do some functions.
Jan 17, 2009 | Texas Instruments TI-84 Plus Calculator
Ti85
kinda. The TI-85 programs differently, lacks a table feature, is not upgradable, has redefinable keys, has a larger screen, is smaller, energy efficient, TI-86 semi-compatible, and is older.
The TI-84+ has archive memory, flash-upgradable, FSTN (clearer) screen, 16*8 screen, USB On-The-Go compliant, almost a centimeter longer, assembly language support, and a tad bit faster.
TI-82: $89
TI-83 Plus: $79-99
Free TI-85: $0
TI-84 plus: $119.99
TI-84+SE: $129-139
TI-89 Titanium: $149
Sep 06, 2008 | Texas Instruments TI-85 Calculator
Cracked Screen
my son dropped his and cracked the screen 2 days ago.Called TI no replacement parts.Spoke to the head of the math dept.at school he also said they have called for repair and no luck. Solution is we have to write a check to the school for $120 since they supply the calculator
Mar 09, 2008 | Texas Instruments TI-84 Plus Silver...
New TI-83 Plus never used with damaged screen
Honestly, the best thing to do would be to take it back to the place you bought it and see if you can return it. It would be less expensive to buy a new one than to repair a broken one. This time I have a suggestion: buy a cover for it if it's going to be in his backpack. I got mine from Staples!
Oct 25, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
846 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
