Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
When I turn it on I hear the printer doing something in the back lower part as if acomodating or spining but the control panel does not light up and the flat bed scaner does not move or lights up , and if I puch any button nothing happens.I opened the left side cover there is a big card with a green light on . I checked all cables and followed them to their connections and they all look ok.... What could it be?
  • efrainwga Sep 28, 2009
    A paper jam is very obvious...I expected a little more help... lets be seruous...
    First of all my question is about a specific printer HP Laserjet M1522nf...the lights do not light up on the top panel ot the flat bed and the flatbed does not move etc...however I hear the normal spining when I turn it on..I also took the left cover and back cover off and on the main board there is a green light that turns on>>>>please give me a little more of help...Thanks
    President:
  • 1,462 Answers
This is due to the BAD FORMATTER..
Disconnect printer from pc. power off. Verify formatter board is installed correctly (specifically connection to dc controller).
If printer has firmware chip (may be built into the board) or memory make sure it is seated properly. power on.
If that doesnt work, then
Try flashing firmware with latest version,download latest driver (maybe current version corrupted).
Cold reset & then NVRAM..if Cold reset doesnt fix problem (print config page, menu map, and network page before doing this)
If anything doesnt work,last resort is, replacing the formatter (these have embedded net card in formatter and maybe its bad)
Please leave me comments, if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 28, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue can occur due to paper jams inside the printer. Please check for any paper jam in these locations--
  • In the automatic document feeder (ADF)
  • In input areas
  • In the output area
  • Inside the product
Please check this link for details--
hp laserjet m1522 paper jam
Find and remove the jam by using the instructions on the following pages. If the location of the jam is not obvious, first look inside the product. If this doesn't help try power cycling the printer and then unplug it for 30-40 minutes.
Please tell me if there are any error messages, blinking lights on the PC or printer.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 26, 2009
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Code error 2257
This error code may be create for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel).
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Office Equipment & Supplies
The touch screen has stop responding. All the other buttons on the control panel work and change the display on the panel accordingly, but you cannot select any options from the touch screen. Any...
PROBABLE CAUSES:
1. The control panel adjustment is incorrect. This adjustment will shift the position of the touch sensor of the LCD unit. Perform the following steps:
a. Hold the Help key and turn power ON.
b. Touch selection #10 (control panel adjustment) on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
Two + (plus signs) should be visible on the screen.
c. Touch the + at the upper right lightly with a touch pen (something with a round tip which is made of resin is recommended as a touchpen). Check the coordinates displayed in the top line at the top of the screen.
d. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
e. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
f. Touch the + at the lower left lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
g. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
h. Turn the machine OFF to store the adjustment. Turn the machine ON normally and check operation of the touch screen.
Dec 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How to fix error c-1183 konica-minolta bizhub 200
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Aug 03, 2010 | Minolta Office Equipment & Supplies
The instrument panel waring lights started to blink off and on than today the anti lock light was on the trac light says its off. The air bag light is on. the speedometer needle jumped all over it wont go...
there should be a ground bar near the drivers seat sometimes located under the lower kick panel pull up the door sill push the carpet back look for corrosion here
Aug 19, 2009 | 1998 Buick Regal
I have a 2210psc printer. The printer keeps wanting to print something I don't want to print. I have hit cancel, turned the unit off, unplugged it all to no avail. Have also unplugged the unit, then...
look into your lower right panel on your computer..there may be a print queue monitor there..open it up, and see if there's something waiting to print there..select it and do a cancel print..that should do it.
Aug 20, 2008 | Office Equipment & Supplies
Printer will not print.
1. what model/type printer is it?
2. Does the power come on? Do you hear motors or fans turning? Do any lights come on?
3. How is the printer connected - Parallel, USB, Network?
4. Will it print test page from the control panel?
Jun 04, 2008 | Office Equipment & Supplies
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
62 people viewed this question
Seeker5211
Seeker5211
