Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Correct lubrication weights and amounts and drain locations for a 1988 HD lowrider
  • buildinguy Sep 26, 2009
    how about tranny and clutch/chain drive fluids?
    how about tranny/clutch/chaindrive fluids?
    President:
  • 1,462 Answers
The weight of the lubrication to be used in HD 1988 is 20w50.
You drain the engine oil from the rubber tube just under the battery tray. There is a plug built into the underside of the tray. ....Have a few rags under the bike ...you can drain oil from this rubber tube
oill capacity 2.8 litres
STEPS TO CHANGE THE OIL:
1. Run engine until normal operating temperature is reached.
2. Disconnect hose behind left side plate. Allow oil to drain completely. Once drained replace. 3. Remove and clean the tappet oil screen located under the plug on the cam case near the rear cylinder tappet block. 4. Remove oil filter. 5. Lube rubber seal on new oil filter with clean engine oil and install oil filter. Hand tighten oil filter 1/4-1/2 turn after seal contacts filter mounting surface. 6. With oil plug and filter tightened, install three 3 quarts (FXR) four 4 quarts (FLT) of recommended grade oil. The oil tank should be flushed with kerosene at the first oil change and at least every second oil change thereafter.
Thanks for using FixYa
RNJ VINODKUMAR
Posted on Sep 26, 2009
Want to change oil on Devilbiss generaotr GBVE8000wk how much oil to replace and what weight oil.
A good 30 weight oil is fine - non detergent oils do have better lubrication qualities than their brethren which nowadays are more common. Get the manual for the amount of oil - depends on crankcase size.
Sep 05, 2017 | Electrical Supplies
1996 lowrider 1340 can only find 1 drain plug and it is 1/2" ??
Hi, Charlie sorry you can not find the first and best tool you ever bought for your Harley despair not, for a mere $10 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below, and for specific information or questions you can reach me at xlch@mail.com. Good luck and have a nice day.
1996 Dyna Lowrider 1340 transmission oil drain plug location Google Search
Motorcycle Repair Changing the Transmission Fluid on 2008 Harley Davidson...
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Feb 19, 2016 | Motorcycles
Jackshaft removal on 1988 HD fx lowrider
get a clymer manual for that model--library has auto and cycle books also
Apr 09, 2014 | Harley Davidson Motorcycles
What weight oil in 2003 hd road king primary case
Hi Anonymous, 32 oz. HD Primary Chaincas Lubricant. Have nice day.
Sep 03, 2012 | 2003 Harley Davidson FLHR Road king
Does changing the oil on a 1998 Ford Contour require any special treatment?
No, none whatsoever. Just drain the oil, oil the filter gasket, and install a new quality filter such as Motorcraft, Bosch, or Purolator. Pour in the correct amount of the correct weight oil and you are done.
May 28, 2010 | 1998 Ford Contour
Where is the drain plug on a 2004 dyna lowrider?
The oil tank is on the bottom of the transmission. Two drain plugs. The center one is the transmission drain, the one towards the front on the left side is engine oil drain.
May 22, 2010 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
How do i drain my 2005 dyna lowrider's brake fluid back resevoir.
Bleed the brake system adding new fluid until the new fluid comes out in to your bleeding bottle you just changed it.
Apr 09, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
Too much oil in engine
The cutting out is just a coincidence. Go with the correct amount of oil. The piston is splash lubricated. Too much oil kills the splash and the cylinder gets poor lubrication. If your model has a carb, ( as opposed to fuel injection ), then clean the carb and air filter then put in a new stock NGK spark plug. This should take care of the problem.
Please rate this solution. Thanks niknak!
Apr 04, 2009 | 1988 Yamaha FZR 250
My forks just dont have enough resistance.
This is an old thread but just in case you haven't gotten the problem fixed, you need to change the fork oil in your forks. The main reason is to make sure you've got the correct amount in them.
If after changing the oil they're still too spongy, you need to change the oil to a heavier weight oil. Use 30 weight "FORK OIL". Do not use any other type of oil as it may foam. Use fork oil only and in the correct amount. Your owner's manual should tell you how much oil to add.
To drain the oil, there is a plug down near the axle on each fork slider. At the top triple trees, there is a large cap on each fork tube. Take this out and add the proper amount of the proper weight oil. Only do one tube at a time. You may have to get the weight of the bike off the front end.
Apr 02, 2009 | 2000 Harley Davidson FXSTD Softail Duece
Lands Phones Logo
41 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
