Question about Air Tools & Compressors
What is the cfm rating on a dayton gas powered air compressor, model # 5f2168
    Habit-Forming:
  • 174 Answers
I would try calling Grainger.ask for tech support on their compressor.you can also order parts for this if they are still available.
Posted on Oct 23, 2009
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
How am I getting oil in the hoses?
Hello Aaron, It sounds as though the piston rings in the compressor pump are not seated in the cylinder. Could they be worn out from use?
Jul 01, 2015 | Dayton Wire Wheels Dayton 2VKY3 Evacuation...
COULD YOU TELL ME HOW MANY CFM THIS COMPRESSOR PUTS OUT
Hello, W/D here.
This link will get you to a free download. Enjoy!
Best regards, --W/D--
Please feel free to rate this solution! Thanks!
Feb 04, 2011 | Ingersoll Rand - Rand Type - 30...
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
The motor runs continuously and the pressure is low. What are the possible causes for this?
You haven't given any model number information, but typically on any air compressor if it won't build pressure, either you have a leak in your piping, tank, hose or the compressor cannot move the required cfm of air. Could be a valve problem or piston, relief valve? Do you hear any air leaking. There are som many different models from cheap throw away compressors to thousands of dollar models. HArd to say without more information
Jul 19, 2010 | Dayton Audio Dayton Speedaire Air...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Nail Gun how to
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun how to
Aug 27, 2008 | Irwin 24" Bar Clamp Multi Position Jaw
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Dayton Fuel Trimmer Shop Heater
flue diameter is 4 inch
Propane Unit Heater, BtuH Input 30000, Full Load Current 2.1 Amps, Gas Inlet 1/2 Inch, Flue Diameter 4 R,V, Motor Power Rating 1/30 HP, Free Air Flow 700 CFM, Height 27 1/2 Inches, Depth 27 5/8 Inches, Width 14 Inches, OC Mounting 8 5/8 Inches, 115 Volts, Energy Saving
Nov 20, 2007 | Dayton (3E379) Heater
Air Tools & Compressors Logo
67 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
