Question about NetGear WGR614 Wireless Router
I am not able to log on my router,it keep saying wrong password. I've went thru the set up steps but it still is not letting me in.what should I do?
When is connect the console cable to my router and reboot it, then i should get the command prompt to configure the router
Contact : 9833796002
Posted on Nov 11, 2009
  • 1,272 Answers
I understand that you are not able to login to router interface. Please note that by default the username for the router is admin and password is password and if that does not work then the only way to login to router is by resetting it to default setings.
Please perform the steps below to reset the router:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
You can now login to router using default username and password.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 27, 2009
I've been using my router since 2006 changing the setting such as password and router name ocassionally. All of sudden today the router quickly resets the security mode to disabled even I choose...
Are you saying you are now locked out of your router, or the wireless security setting will not change? When you press the reset button are you holding it in for about 10 seconds? If so it should go back to factory settings and a local ip address of 192.168.1.1, to log into the router there should be no username and admin as the password if it went back to factory settings. Have you upgraded the bios on this router? I would start there first, this could be a bug in the software.
Nov 07, 2012 | Linksys Wireless-G WRT54G Router
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
Both My Inspiron and linksys will not connect to my ISP. They say both are receiving an invalid IP address! I have used all trouble shooting techniques including trying to release and reset! Even went as...
Step 1: Plug the computer (ethernet wired) directly into the modem. Power cycle the modem and when all the light come on you should have internet. If not call your ISP to trouble shoot.
At this point we should be able to determine if it is a PPPoe connection (needs username and password to connect) or if it logs in automaticly.
Step 2: Plug the router back into the modem and the computer plugged wired (ethernet) to the router. Remove power from both the modem and the router. Plug the modem back in first, once all the lights are on plug in the router. Try to connect.
Step 3: Log in to the router via its IP address (normally 192.168.1.1), if no one has reset the user name password it should admin for both. If it has been reset, you will need to know what the user name and password are to continue.
Step 4: Under setup if in step 1 you found you needed PPPoe, then you need to set that under the setup tab. Make sure you use the user name and password provided to you by your ISP. If you dont need PPPoe then make sure this is set to obtain IP automaticly.
Step 5: save settings. Once the router restarts, try to connect again.
If these step do not work, let me know:
1. who is your ISP?
2. What modem do they use?
3. What is your IP address when plugged directly into the modem?
4. What is your IP address when plugged into the router?
I will be around for about 1 more hour, its 2PM central time now.
Jul 21, 2011 | Computers & Internet
How do i set up password to keep anyone from using my wireless connection
Turn the unit on and open a browser window on your computer. Be sure that you've selected the Name of the router, default is linksys, as the network that your computer is connected to. Browse to the Admin page of the router by typing in its IP address, default is 192.168.1.1. You should see a logon screen. The unit should ship with a default password, which is admin. That is, you leave the username field blank and type the word 'admin' (no quotes) into the password field. (Once you are logged in, you can change the password for logging into the router thru Administration --> Management. You should see a two boxes to verify the new password that you would like to create.) For creating a password for the secure Wireless connection, go to Wireless --> Wireless Security. To set up the Wireless security, tho, I think you'll have to connect with an ethernet cable. You can then walk thru the setup. Use WPA2 as the security, if possible.
Jun 17, 2011 | Linksys Wireless-G WRT54G Router
How can i reset the password to my wireless router (wr850G) I've held down the reset button for more then 30 sec on and off with no luck and when I try to log into the router through a wired connection...
Did you try unplugging it, holding the reset button for 30 seconds, then plugging it in (while holding the reset button), then (after I'd say like 5-10 seconds) letting go of the reset button? Also, if you're seeing a blank configuration page, it could be that the username/password combination is wrong. Try using username "admin" and password "password" "1234" "0000" "admin" and leaving the password blank. One of those combinations should work.
If none of those work, unfortunately, it might be that somehow the router got damaged or broken somehow. You can try some of the steps from the manual (located here) to get it to work again, but you might want to look into a new router.
Jun 16, 2011 | Arris WR850G Router (DHWR850G)
I cannot get on my sight, it says i have the wrong password
Try these default username password combinations:
Usernames: *leave the field blank*, admin, user, username
Passwords: *leave the field blank*, admin, pass, password
Any combination of these may work.
*Do not do this next step if you have a modem/router combo device that your ISP provided you*
If the above did not work, you may have to find a pin or paperclip to push the reset button in the back. This will erase all the previous settings that may have been set on the router. You should setup security as soon as you log into the router settings page.
May 26, 2011 | Computers & Internet
D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Feb 01, 2010 | D-Link DIR-615 Wireless Router
Don't know the password for my belkinwireless G router how do I reset it to factory settings and what are the factory settings
Go to your router thru your browser just like a real web site. (my Belkin is: http://192.168.2.1/index.html) From there log in. Default password is blank/no password. After logging in you will find the area to create passwords.
Aug 26, 2009 | Belkin Computers & Internet
When installing router, just keeps saying "waiting for router"
for your settings open your internet browser and type 192.168.1.1 for your router settings.
May 17, 2009 | Linksys Wireless-G WRT54G Router
DI-624 ROUTER INSTALL WITH OUT CD
Disconnect your modem and other devices from your wireless router and connect your laptop/PC to your wireless router through ethernet port ( keep your ip settings to automatic in network settings of your Laptop/PC) then type the ip number 192.168.0.1 in your web browser's address bar.
Here you are you will get the login page of your router.Default login id is "admin" and password is "password" if this password is wrong then try with the password "admin".
After logging into the page you will find the wireless security tab.in that you can find your security key.
May 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
NetGear WGR614 Wireless Router Logo
173 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
