Question about Zio Corporation Dazzle DVD Complete (DM-10000) for PC
Dazzle DVD Complete won't recognize DVD drive
When i try to burn project to DVD it won't give me the option to change drive to my DVD burner dvrive. It only lists my CD burner and cannot find option to change. Please help.
Computer does not recognize there is a disc in the DVD drive
If this is a Windows computer. Make sure that you have the proper drivers installed.
Is the disc scratched? that could also be an issue.
Feb 28, 2011 | Computers & Internet
Cant burn to DVD-R from windows DVD maker
  1. Make sure that you have at least five gigabytes of free space on your hard drive. To check this, go to “Start” and select “My Computer.” Look to your “C:” drive and make sure that you see at least 5 GB free or something similar.
  2. Step 2 Insert a blank DVD into your DVD drive.
  3. Step 3 If you have “Autoplay” enabled, a popup screen should appear asking you what action you wish to take. If so, select “Burn a DVD Video Disc using Windows DVD Maker.” If not, go to Start and then “Search” and type in “Windows DVD Maker.” After it appears in the list, select it by clicking on it. The Windows DVD Maker screen should appear. If you want, you can “uncheck” the box that says “Don’t Show this Page Again.” If you do that, this screen will appear the next time you burn a DVD.
  4. Step 4 Click on the button that says “Choose Photos and Videos.” On the next page, you are to select the files that you wish to burn. You can click the “Add Items” button at the top and then search through various folders on your computer to find the file that you want or you can open the folder that has the file(s) you want, “left-click” the mouse and hold it down over the item and then drag the item into the blank list in the Windows DVD Maker screen. Either way is acceptable.
  5. Step 5 Go to the bottom of the DVD screen and click inside of the box that is marked “Disc Title.” You can replace the date with whatever name you want to give your soon-to-be DVD. If you do not want to go too in-depth with this software at this time, skip down to step 8.
  6. Step 6 For the most part, you can leave the “Options” button alone. However, if you choose to click on it, you need to understand what the settings mean. For instance:
    • “Start with DVD Menu” means that, whenever the DVD is inserted into a player, the home screen will appear and you will have the option of selecting Play or which scene you wish to view.
    • “Play Video and End with DVD Menu” means that the movie will start the moment the DVD is inserted into the player and return to the home screen when the movie ends.
    • “Play Video in a Continuous Loop” means that the movie will keep playing as long as the DVD is in the player.
    • “DVD Aspect Ratio” refers to the screen the movie will play in. 4:3 is the standard video screen for the United States, while 16:9 is the international standard.
    • “Video Format” determines which kind of DVD player you disc can play on. “NTSC” refers to American DVD players. “PAL” refers to DVD players made abroad.
    • “DVD Burner Speed” refers to how quickly your DVD burning project will take to be completed.
    • “Temporary File Location” is the reason you need at least 5 GB free. When you burn a DVD, your computer makes a temporary copy of your new disc and stores it on your main hard drive. If you don’t have at least five free, the DVD burning process will be significantly slowed.
    Simply click cancel if you decide to make no changes under Options.
  7. Step 7 Your DVD software will automatically burn DVDs to your “E:” drive. However, if you have a separate DVD burner, you can select “DVD Burner” and choose your device instead.
  8. Step 8 Scroll to the bottom and click “Next.” The “Ready to Burn Disc” screen should appear. On this screen, you have the option of choosing the look of your DVDs home screen. If this is not important to you, you can skip down to step 13.
  9. Step 9 “Preview” allows you to see what how you DVD will behave in a player once it is completed. “Menu Text” allows you to choose the Font that you want your DVDs title— as well as the “Play,” “Scenes” and “Notes” buttons—to have. When you click that button, you will see various tabs on the next screen. From there, you can change the name of any of the buttons. For example, if you would prefer the Play button to be labeled “Happy Dragon Fun Time,” this is where you would type that in. The “Notes” button is unique. If you delete the word Notes and keep the Notes box empty, the button will disappear entirely on your new DVD. I recommend changing the word Notes to Synopsis and adding a summary of your movie to the large, empty Notes box.
  10. Step 10 Click “Change Text” to complete the changes you made or “Don’t Change” to reject them.
  11. Step 11 “Customize Menu” allows you to change the particulars of your DVD. You can change the overall shape of the buttons at the “Screen Button Styles” tab or add Back- and Foreground videos to the home screen from anywhere on your hard drive. You can even add an audio file of your choice. Click “Change Style” to complete the changes you made or Don’t Change to reject them.
  12. Step 12 “Slide show” allows you to create a slideshow to appear when your DVD is inserted into a player. You can add music and whatever pictures you want. You can also change the duration that each picture stays up on the screen. Click “Change Slide Show” to complete the changes you made or Don’t Change to reject them.
  13. Step 13 You should be back to the Ready to Burn Disc screen.
  14. Step 14 On the right hand side of the screen, you should see a list of “Menu Styles.” Select the one that you want but keep in mind that each Menu style has its own font and button shape.
  15. Step 15 Click “Burn” to begin the DVD burning process or Cancel to exit.
  16. Step 16 After the disc is finished, your computer will ask if you wish to make another copy of the disc. If you select “OK” you will then have to insert a new DVD and re-burn the movie. However, you will not have to start over completely. If you select “Cancel” or click the red “X” in the corner, you will return to the Ready to Burn Disc screen. If you click the red X again, you will be asked to save your project. Name the project whatever you wish. Your DVD is now burned and ready to use and you have a copy of the specifications you made. If you want to go back later on and re-burn this DVD, all you need to do is click the “Saved project file” and have a copy of the film on your hard drive.
  17. if the problem persist then you have a problem with your storage device.if not satisfied please contact me with any question you need to know
Sep 10, 2009 | Pioneer (DVR110D) DVD RW Dual Layer Burner
I have 2 dvd writer drives that are not being found by software
get on the computer manufacturers website and download the drivers for your dvd on there.
May 24, 2009 | HP DVD1040e DVD-RAM Burner
Upon installing Dazzle, there was good audio sound but no video.
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that Dazzle is selected in the "select source" to set the total recording time, if the Dazzle is not available, try other USB ports or download the drivers in the link below)
Apr 10, 2009 | Pinnacle Dazzle DVD Recorder
Will not read my burned dvds
In this case need update the Firmware of DvD/Cd Rome
Apr 10, 2009 | NEC Computers & Internet
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Pinnale Dazzle DVD recorder doesn't recognize VCR
1. Select source:
2. Select Burner
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
Dec 09, 2008 | Pinnacle Dazzle DVD Recorder
LaCie DVD Burner Not Doing Much of Anything
You should check for corruption of your CD/DVD burning software from whereever you got it. Sometimes some burning software isn't good enough to work adequately. I'd test some new burning software to see if that is the problem, if upbrading your burning software doesn;t do the trick. You can downlowad free trials of Roxio, NTI, and other good burners to test this hypothesis. And, of course, try calling LaCie support.
Mar 06, 2008 | LaCie 16X LIGHTSCRIBE DL d2 DVDRW USB2&FW...
I have problem with my AVERATEC COmputer
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
Feb 22, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
Zio Corporation Dazzle DVD Complete (DM-10000) for PC Logo
124 people viewed this question
Top Zio Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zio Computer and Internet Expert? Answer questions, earn points and help others
