Question about Motorola Mobility RAZR V3
My razor v3 battery indicator blinks orange now is there a problem
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Blue tooth light won't shut off on my Razor V3, setting are off and not connecting. Is this wearing down my battery?
Is it an actual light or just the indicator? If it is the indicator and it is bothering you then you should be fine to disable it in your settings.If you find out it is the indicator there is no drain on the battery.
Jul 06, 2009 | Motorola Mobility RAZR V3
Is it normal when the chage indicator is blinking orange during charging?
It depends on the model, however blinking orange is common for charging. Normally Red is critically low battery, orange is low battery power, blinking orange is charging, and green is charged.
Jul 03, 2009 | Televison & Video
Car charger without overcharge protection - fear of overcharging Mororola Razr V3
you should purchase a mobile v3 car charger for the phone and do not use the other one you have
Sep 28, 2008 | Motorola Mobility RAZR V3
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Motorola Razor V3
i use skin manager to downloading skins on V3 razor but there is a problem here i download a theme on my mobile there is a option of cycling ur mobile i accept this option & my phone getting restart & then blinking a white screen my mobile is not getting on
plz help me
what can i do for this proble
just email me at
asia@xylyx .biz
Dec 22, 2007 | Motorola Mobility RAZR V3
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
