SKY DIGIBOX 2nd RF frequency
I have just purchased a new HD freeview TV and want to connect myTV-link from my sky digi-box that i used before on my old 2nd TV.
I need to know what frequency to tune into, or how the fr no's ie 32, 55,60 equate too the mhz that i need to know to tune in the new TV ie 5556.30 mhz. If any body knows that would be great thanks.
  • 325 Answers
Your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Cheers Little Dish Fitter
Posted on Sep 28, 2009
  • Robert Oct 08, 2011
    ****: I need digibox and have it installed can you do it? call 09157506909 Robert
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Cant record sky
connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Mar 01, 2009 | Panasonic DMRES20D DVD Recorder
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Jul 20, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Using an old SKY digibox for Freeview ?
you have a smartcard for that box ?, cause without that card, you won't see any of the channels at all.
Nov 11, 2007 | Televison & Video
Connection Nightmare
try here in this forum http://radioandtelly.co.uk
they will give you some ideas t oconnection set up .
riz.
Nov 02, 2007 | Daewoo DVDRW11 DVD Recorder
Televison & Video Logo
918 people viewed this question
Top Televison & Video Experts
