Question about Motorola Mobility RAZR V3
Cant open my message in box, keeps taking me back to message menu
  • 4 Answers
Try resetting the phone?
resetting it should clear the problem. but it will delete any data you have. such as pictures, videos or texts. so if you have any important data, which you havent backed up, say so, and i will try and find another alternative, but heres how to reset it.
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
hope that helps :)
Posted on Sep 26, 2009
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
How to forward sms in GT-I5500 ?? i cant Understand
Go to messaging Icon on your phones main menu(if not already open) and open the email you want to forward.
Place you finger on the message and HOLD it there for about 3-5 seconds.
A Dialog list box will appear, scroll down to where it says forward and in the to: box start to add the number or the name of the contact you want to forward the message to. AS you type, just below a list will appear if it's in your contact list.
Next scroll down and tap the send button.
Job Done
Feb 15, 2011 | Health & Beauty
N96 keeps crashing, shortcuts missing, messaging already in use
Its been a year so there must be definatel a newer firmware version available for your phone. Just get the Nokia Update Manager software in your computer and try updating the phone. Should solve all your problems and just make sure that you take a back up of your data because after an update you will loose all your phone memmory data. Mass Memory stays unaffected.
Sep 18, 2009 | Nokia N96 Smartphone
Downloaded explorer 8, now cant open anything at all. just says isass.exe system error, security accounts manager initalization failed because of the following error. The handle is invalid. error status:...
Well then... you should restart your machine and press F8 (on your keyboard) continuously until prompted with a menu.
Select the option "last known good configuration"... that should bring your machine back to how it was before IE screwed it up.
Hope this helps!?
Jul 07, 2009 | Microsoft Internet Explorer 8
My starview 3 box codes keeps going to ff
Press menu..then type in 1570..this will open another menu..go to default and press the default key..then press back..and go into nagravision you should be able now to find your provider..select that and enter your 00 code and store then change to 01 and enter that code..store and exit..make sure your emu key is on it's below the default key..then exit and all should work.
Good luck
Gord
Mar 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
My V3x doesnt let me read text messages
I just had this problem, after pulling my hair out, then trying any solution i found on here nothing worked. <br />So i tried something myself i had a lot of messages in my out box so i started to delete them on bulk with multiple delete, after i had emptied the out box, miracle of miracles it worked i can no access my in box, about time too! <!-- from fixya rte -->
Mar 14, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I accidently deleted something on my phone(motorola q 9m ) now i keep getting a message that says- error opening the shortcut or locating the target filename.- I cant open anything from my start menu and i...
you should be able to set it back to factory default settings and only lose the ring tone and wallpaper message sound etc.... they should all still be there after but you will need to reset the phone to how you want your profile to look again.
Oct 25, 2008 | Motorola Cell Phones
RINGER STYLE
Try doing a master RESET first. This will reset everything on the phone back to factory but you will keep all your information. If this doesn't work, I would try a master CLEAR.
Keep in mind that if you do a master CLEAR, this will erase any aftermarket data in the phone. Phone numbers, pictures, multimedia messages, text messages etc., and also set everything back to factory default.
Both of these options can be found under MENU>SETTINGS>INITIAL SETUP> (at the bottom of this list you will see both options vor Clear and Reset) - the code (unless you have changed it) is 6 0's. (000000).
Please remember to rate if this was helpful. If this doesn't work, there are alot more options, this is just the easiest and most common fix for something like the problem you are having.
Sep 04, 2008 | Motorola Mobility RAZR V3
N73
Firstly open the menu- then go to control panel- then log -open it up - optiions clear all log.
u must store your messages in memory card and not your phone memory. Deletae unwanted messages from the message menu.
Open messages- then press options then settings then "others" then "memory in use " select use memory card .
ambove this option is the no of messages that can be stored - there type in 999. Close all and come back. to your menu.
Please feel free if u have some problems
Mar 09, 2008 | Nokia N73 Cellular Phone
Lavasoft adaware problem
Are all you icons at the desktop also gone and are now links but will not open?
If yes pls post back that we can provide you with the solution.
Kind regards.
Feb 13, 2008 | Computers & Internet
Motorola Mobility RAZR V3 Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
